axle boot replacement - Dodge SRT Forum
post #1 of 4 (permalink) Old 01-26-2010, 07:53 PM Thread Starter
Quoted: 0 Post(s)
My p side axle boot tore so i had to do something to save me some money and refrain from buying another axle. It is the outtermost to the wheel boot. So i got a boot from dodge and it came with the boot..the 2 clamps..a bottle of grease and some kind of ring i havent figured out what it is yet. But i took a pair of snap ring pliers pulled the cv joint off and it is not a straight shaft. But i cant fit the inner part of the boot over this one ring on the shaft! does it come off or do i need to find a way to get the boot over it. I reaaaaly hope someone has done this or knows what im talking about. Thanks! ill try my best to explain if you need me to
1 srt4 U is offline
post #2 of 4 (permalink) Old 01-27-2010, 07:54 AM Thread Starter
Quoted: 0 Post(s)
Bump for some help
1 srt4 U is offline
post #3 of 4 (permalink) Old 01-27-2010, 03:09 PM
Quoted: 0 Post(s)
Though I have a GT Cruiser... I believe we share the same axles, so I'll attempt to offer whatever info I can.
Is it a Circlip? That clip sits in a machined groove on the axle's outer spline and holds the outside CV Joint onto the axle. If yours is missing on the axle, that means it either popped off when you pulled the CV off the axle, or it's still inside the CV Joint itself. Look inside the CV and behind the cross for the clip. Fish it out if that's it, and use the new one.
If the ring is more like a sleeve and covers the splines, then it's to protect the new boot from getting damaged from the splines during installation.
In older GT's (2003-2005) for example, there is also a thin metal shim that sometimes came with new axles and/or boots. That shim was placed on the CV Joint stub axle splines that went into the hub. It acted as both a shim and a scraper to keep the backside of the hub bearing clean and free from brake dust and other debris that would shorten the life of the wheel bearing.
Huh... come again? It's not a straight shaft? Does that mean it's bent? If the shaft is not straight, then you'll need to replace the entire axle. The interconnecting shaft (running between the inner and outer joints) is as straight and true as possible. There must not be any run out off the axis.
I believe you may have found the Circlip. If it's sitting in the axle's groove, you must remove it before installing the new boot. If you don't you'll damage your new boot and it will leak on the small inner area once warmed up.
Once you have that Circlip off, clean up the shaft, then slide the boot onto the shaft until it reaches the groove on the interconnecting shaft. That groove is where the boot must rest for proper sealing. There is a raised bead on the inside of the boot where it sits on the shaft... make sure it goes all the way on until that groove is covered by the boot and the raised inner bead is now flat for the small boot clamp to sit on squarely.
Now, the trickiest part of installing the new clamps are to make sure they're not only on tight, but to make damn sure the crimp is low. The only way I know how to do that is by using a boot band crimp tool. Mopar Special Tool C-4975A. It's a simple tool and you ought to be able to find one at any local auto parts store. It won't be the Mopar crimp tool... but the design is the same, just a different name is all. Some parts stores will even loan them so you don't have to buy one.Here's one currently on Ebay. If anything... the pic is worth looking at.
Regards!
GT Bruiser is offline
post #4 of 4 (permalink) Old 01-31-2010, 10:45 PM
Quoted: 0 Post(s)
Bump for some help
So, did you get this one fixed? Howabout a follow-up?
Regards!
User Tag List
Linear Mode Linear Mode
