Old 10-16-2009, 09:28 AM   #1 (permalink)
Crazyced's Avatar
Member Number: 56385
Question ATC street disk?
My stock clutch finally started slipping with my Stage 3 Toys + bold ons. I want another good daily clutch that will be able to withstand runs with slicks (I don't have slicks yet) from time to time.
Would the ATC street disk be good enough for that?
Crazyced is offline   Reply With Quote
Old 10-16-2009, 10:05 AM   #2 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
should be fine! would be even better if you got the upgraded act street disc with extreme pressure plate
Pittsburgh Penguins 14-8-0 28 points
Old 10-16-2009, 10:17 AM   #3 (permalink)
OrionR12's Avatar
Member Number: 21193
Trader Rating: (146)
I am have a big wheel S3 and my ACT street is slipping...
-ryan-
'04 eBlue SRT-4 (44lb SNL Shocker Stage 3 w/ toys)
387hp 442tq w/ clutch slipping & kicked out HOM
Award winning thanks to DARKSYDE!
In memory of Steven Nightshade Lorenz
OrionR12 is offline   Reply With Quote
Old 10-16-2009, 10:17 AM   #4 (permalink)
Crazyced's Avatar
Yes, I'm considering it.
Old 10-16-2009, 10:20 AM   #5 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (29)
I would not run a street disc on slicks and Stage 3. It's going to slip. Get a 6 puck if you plan on putting slicks on it.
Old 10-17-2009, 01:55 AM   #6 (permalink)
Member Number: 68019
im considering the same clutch just without the xtreme pressure plate... not makin nearly as much power as you tho
shreddedxbaby is offline   Reply With Quote
Old 10-17-2009, 10:37 AM   #7 (permalink)
Crazyced's Avatar
That's what I don't get. The XTSS for our car is rated at 558ft/lbs of torque. My stage 3 won't be even close to that.
How much torque do you put out?
Old 10-17-2009, 12:16 PM   #8 (permalink)
Philth's Avatar
Trader Rating: (29)
It's not the rating of the clutch, it's how fast and down low in the power band the TD05 comes in at, especially with HOM on. I've gone through tons of clutches, all which had only slipped at the track with slicks on, and HOM on; WOT shifting all gears. This includes the old style ACT 6 puck, street disc, DCR PS2 (discontinued), SBC Stage 5x (Discontinued).
Old 10-17-2009, 12:32 PM   #9 (permalink)
Member Number: 65222
if you want this car for the street put the street disc in there. if you want the car for track only put a 6 puck in there. its not that hard to figure out they have a street clutch for a reason...possibly the street?
SiRt4 is offline   Reply With Quote
Old 10-17-2009, 12:35 PM   #10 (permalink)
and the xtss is great to have, it would save your input shaft dearly. i run the act street clutch& xtss plate and have a dbb 30r and i have no problems. lol its common sense on here but from what ive seen theres alot of ppl on here that dont this car as well as they think and point some ppl in the wrong direction with things
Old 10-17-2009, 12:36 PM   #11 (permalink)
and i run street radials not slicks and hook up fine
Old 10-17-2009, 12:40 PM   #12 (permalink)
looks like its a driver error and not a clutch error.. 5 clutches?...i feel bad for ur car man
Old 10-17-2009, 12:54 PM   #13 (permalink)
Philth's Avatar
Trader Rating: (29)
11.81 @ 118 here in Vegas dude....come out and try....wait you don't even have a Stage 3..you have about what 2,500rpm of useable power band??
And until you put on a pair of slicks, do you even know what the hell your talking about?
Old 10-17-2009, 04:08 PM   #14 (permalink)
Member Number: 33203
Trader Rating: (25)
lol at this idiot. I have an UNSPRUNG 6 puck in my 500+hp on pump daily driver. Maybe I should have left the stock clutch in since I drive it on the street. pftt
And if you hook on drag radials with a big turbo setup, you need some help cuz your shits weak sauce.
Precision 6057@30psi on pump
8.50@87 on 10psi w/2.0 60 ft (wg pressure on 30 psi tune, no 2 step)
Contact Turbo666/TDSaaron for your tuning needs.
turbojonsrt4 is online now   Reply With Quote
Old 10-17-2009, 04:14 PM   #15 (permalink)
conroy9940's Avatar
lol at you... the act street disc with extreme pressure plate will be fine... why do i know this?
look at 90vnt, he is using a e3 (44# wheel) and making over 500 ft/lbs of torque and 430+ whp... yeah your right, the street disc wont work at all
yeah i think im going to downgrade to a stock clutch as well since i drive it 90% of the time on the street and because he knows it all
Page generated in 0.15069 seconds with 13 queries
