Old 11-01-2009, 01:32 PM   #1 (permalink)
ibnzmonkey's Avatar
Member Number: 36611
Default Alternative to Rage's HTOB
So after my clutch fork destroyed itself a few days ago Ive been researching alternatives. I found out about Rage's HTOB but i learned they don't sell them anymore. I'm all about reducing the amount of moving parts in any type of machinery so the HTOB idea really stuck with me. Ive seen a few custom setups on here that looked impressive. Now Ive found 2 types of HTOB on Ebay that are very reputable and look like they can do the job.
Here's the first.
HYDRAULIC THROWOUT BEARING,LINE KIT, & BLEED HOSE,STOCK:eBay Motors (item 220449951063 end time Nov-06-09 15:04:13 PST)
And the second.
HYDRAULIC THROWOUT BEARING,LINE KIT,& BLEED HOSE,RACING:eBay Motors (item 220449951167 end time Nov-06-09 15:04:39 PST)
The first looks like it will definitely work. But i don't know the Diameter of the bearing retainer collar on the input shaft. I need to measure that in a sec. The only problem i see with this one is that it looks like it would be a PITA to mount with some sort of plate like Rages'.
The second one looks more promising. It has a base plate built in and looks sturdier. The only problem i can see with this one is that the Engagement face of the bearing (the part that pushes on the clutch fingers) looks smaller in diameter than the first option.
I'm not trying to bash Rage here, I'm just providing a viable alternative to waiting. Im all about supporting the vendors. I just dont want to go back to the shitty TOB, Fork, Pivot ball setup. Discuss plz.
" Raise boost till you blow the head gasket(or crack pistons), then back off slightly."
ibnzmonkey is offline   Reply With Quote
Old 11-01-2009, 05:12 PM   #2 (permalink)
Member Number: 52407
I have been wanting to do the same thing. I don't know how to make the plate or whatever to mount the HTOB. Is that something we'd have to make up ourselves?
It is hard for me to picture what all it would require without having dropped the transmission yet and seeing how it all works in there.
Here are some links to the parts a friend provided me with, I believe these are the same parts Rage used
Russell Performance 640281 - Russell Clutch Adapter Fittings - Overview - SummitRacing.com
Howe Racing 82870 - Howe Throwout Bearings - Overview - SummitRacing.com
Howe Racing 8289 - Howe Remote Bleeder Kit - Overview - SummitRacing.com
Howe Racing 3374 - Howe Racing Brake Bleeder Screws - Overview - SummitRacing.com
Before the links quit working:
russel performance 640281 howe racing 82870 howe racing 8289 howe racing 3374
7055 is online now   Reply With Quote
Old 11-01-2009, 10:00 PM   #3 (permalink)
Member Number: 65408
Trader Rating: (20)
my trans is already out what kind of installation process am i looking at? thanks
1 srt4 U is offline   Reply With Quote
Old 11-01-2009, 10:18 PM   #4 (permalink)
boots's Avatar
Member Number: 67116
Hope you guys figure something out. There is another person who makes a kit for our car. But he wants to much in my opinion $950. I would call the one of those places and see if they can make something to our specs or have something already available.
2004 stage 2-AEM ems-DCR intake manifold-crane 16's(stock valve train)-act clutch-dss axles-boomba fuel rail-boomba mounts-boomba throtle body-3in side exit exhaust- maddog 58 STS-built trans( Rage accelerator, Rage 3/4 fork, and p-werks selector)- GT3076R
Soon to come, my high compression build New turbo setup and transmission setup
boots is online now   Reply With Quote
Old 11-02-2009, 09:28 AM   #5 (permalink)
ibnzmonkey's Avatar
Well, my transmission is sitting in the kitchen as we speak. lol. As its my only car right now I'm going to have to throw in my spare Fork and TOB for the time being. I am going to Email the manufacturers of the two aforementioned bearing i posted earlier and see what i can get. Hopefully we can get a cheaper priced alternative.
As for the installation process? I'm not sure exactly. I would need to have both the bearings in front of me so i can figure it out. Unfortunately that's what i might do.
Hopefully i can get the ball rolling on this and get something prototyped soon. Thanks for the links 7055. I was trying to figure out how to connect the braided hose to the master cylinder.
Old 11-02-2009, 09:32 AM   #6 (permalink)
boots's Avatar
Project Neon Racing Parts
Old 11-02-2009, 09:50 AM   #7 (permalink)
ibnzmonkey's Avatar
Quote: Originally Posted by boots View Post
Are you serious? $975 is ALOT for what you get in that kit. Plus, that bracket is meant for the T350 manual. Ill get something in the works soon, hopefully i can produce an all inclusive kit for under $250.
Edit: Heres something else i found.
HYDRAULIC THROWOUT BEARING FOR STOCK STYLE CLUTCH - Transmissions, Clutches - Drivetrain - Circle Track Supply, Inc.
Old 11-02-2009, 09:56 AM   #8 (permalink)
Member Number: 60592
i just did a install on a evo8 with a HTOB and the set up is pretty sweet. will you have to shim it? cuz we had to on his. it came with rings and washers. we wasnt sure how the rings worked so we used washers behind it.
stock pcm with bolt ons 13.49@103.89
05 Commemorative Edition
PW1 ACC,ARL,GWA #74/200
SRT_PAPA is offline   Reply With Quote
Old 11-02-2009, 09:58 AM   #9 (permalink)
boots's Avatar
That kit is for a 1st gen. He just came out with one for the srt-4 for $950, he doesn't have it listed.
Old 11-03-2009, 01:23 AM   #10 (permalink)
Bebo's Avatar
Member Number: 46331
How much is Ragetek's? Will it work with thier dogbox? (don't have one but, it's still a possability in the future) Anyone know a machinist to make adaptor plates?
Quote: Originally Posted by joe r View Post
bare foot,I race naked.
LOL...
joe r
Quote: Originally Posted by Pablo View Post
Try and post some pics if you can.
Bebo is offline   Reply With Quote
Old 11-03-2009, 01:29 AM   #11 (permalink)
It was $380 I believe and it isn't offered anymore, hasn't been for a while.
Old 11-04-2009, 12:18 AM   #12 (permalink)
Bebo's Avatar
See if you can get the plate design from them & make some plates. Now that I think of it Bitts is a machinist see if he could work something out for ya.
Old 11-04-2009, 12:23 AM   #13 (permalink)
Member Number: 28737
Trader Rating: (82)
If someone can get me the plate design I can take it to Boomba when I go and find out how much it'd cost.
Token Boomba Racing SRT-4
Maddog STS Info
taco is offline   Reply With Quote
Old 11-04-2009, 12:28 AM   #14 (permalink)
This is most likely what I'm going to do. Use the parts I listed, which I believe are the same as Rage's, and fab up a plate like Rages here. Or if you look closesly there are two bolts holes. I could just bolt a stud into that upper hole and have that wedge against the HTOB so it doesn't spin. Sounds ghetto but it's pretty much the same thing Rage did. Then you wouldn't need a custom plate or anything. Then just get some shims if need be and follow Rage's how to, might not even need shims.
This is Rage's
I did have an idea earlier with a Tilton HTOB I saw that had tabs on it that looked like it very nearly lined up with the two bolt holes on the t850 but I was told it doesn't line up and that HTOB wouldn't work on the t850.
Anyway don't get the wrong idea. I haven't even dropped my transmission yet, I won't have time until Christmas this is just my preliminary idea. I think it'll work though.
Old 11-04-2009, 08:26 AM   #15 (permalink)
boots's Avatar
Tilton makes a HTOB that works because that's what that guys uses that sells the kit for $950. I would have to find somethign with a bigger face on it since I'm using the Rage twin disc.
Page generated in 0.16936 seconds with 13 queries
