Accelerator shaft noise under load (may not be the input shaft)
I'm really just looking for peace of mind here. I don't have much experience with straight cut gears (the first gear on the rage accelerator shaft is straight cut), so I don't know whether or not I should be worried.
I just finished my trans build, listed are all the new parts that I am currently running: ACT 6 puck sprung w/ prolite flywheel, new TOB, new TOB fork, Rage accelerator shaft w/ pilot bearing, Rage 3/4 shift fork, all new snap rings etc. when I rebuilt the trans.
The car shifts flawlessly, initial engagement into first gear is a little rough (vibration and clutch chatter). There are a couple new noises that I didn't notice before on my stock transmission (had a SBC stage 3 modular).
1 - in first gear, when launching the car sounds like it has a damn supercharger. There is an audible whine coming from the trans.
2 - in ANY gear, while under load, there is a rattling sound (metal on metal). It sounds almost like a loose flywheel bolt, HOWEVER when the engine/trans are not under load the noise is not present (when coasting and decelerating).
Any ideas? Other accelerator shaft owners please chime in...
