Old 11-03-2009, 10:23 AM   #1 (permalink)
srt41981's Avatar
Member Number: 71640
Question 75-90 Synthetic Gear Oil Safe In T-850?
has anyone used this fuid? wondering if it would work better than the atf4. i have 72k on stock trans and axels, upgraded clutch, new cryo fork, new tob and no shifting issues. would just like better protection to keep it that way...
srt41981 is offline   Reply With Quote
Old 11-04-2009, 06:45 PM   #2 (permalink)
TurboMoparGod's Avatar
Member Number: 33697
Trader Rating: (58)
I wouldn't personally use that weight oil. I've used RP syncromax and amsoil's syncromesh fluid with good results. And no you don't need the friction modifier with the oils I listed if you have an lsd equipped srt.
Forward Motion 302-658-2829
http://www.forwardmotioninc.com/html...og/page18.html
Sales@ForwardMotioninc.com
Stock turbo 12.82@107mph DR's
E1 Turbo 12.48@115mph DR's slipping stock clutch
E3 47lb Turbo 1/8 7.923@93.67 1.95 60' 235/60/15 DR's
TurboMoparGod is offline   Reply With Quote
Old 11-04-2009, 08:06 PM   #3 (permalink)
Member Number: 36825
I use BnM trick shift and the lsd additive.If I used the above fluids I would still use the additive it helps gears from shearing.
SRT Jeff is offline   Reply With Quote
Old 11-04-2009, 08:14 PM   #4 (permalink)
srt4rmp's Avatar
Member Number: 13499
i am using 75/90 right now and have been for the last six months i change every 6months and since i have been shifting like a hot knife through butter! i will continue to use it until i read somewhere that it will hurt the trans mobile1 75-90 is the way i go
srt4rmp is offline   Reply With Quote
Old 11-05-2009, 08:06 PM   #5 (permalink)
srt41981's Avatar
i went ahead and went with the penzoil synthetic syncromesh 75/90 since its what we have at work. not sure what to think of it yet. i might give it a few days and if i don't notice any difference i'll switch back to atf-4. not sure if its in my head but car seems slower now lol
Old 11-06-2009, 02:40 PM   #6 (permalink)
SoloSrt's Avatar
Member Number: 46682
Have order the amsoil's syncromesh... and have been wondering about this. Would it do you any good to add the LSD additive anyway? What about this amsoil fluid makes it so that the LSD additive, or "friction modifier" is not needed??
Thanks for the time.
05' Stone White / 17X7.5 Kosie K-1s / 12.2" Wilwood BBK (Dynalites) / Stage 2 IPP Coilovers / Energy Suspension full chassis bushings / Custom Built Boost Leak Tester!
SoloSrt is offline   Reply With Quote
Page generated in 0.12319 seconds with 13 queries
