4th Wheel Bearing Change - Front Left - Dodge SRT Forum
 6Likes
  • 3 Post By stowaway
  • 2 Post By 04itr
  • 1 Post By T4EaterJonny
post #1 of 11 (permalink) Old 06-15-2017, 09:26 PM Thread Starter
Supafly's Avatar
Quoted: 2 Post(s)
Looking at my 4th wheel bearing change on the front left (102k miles). No issues on the other 3 wheels.
Anybody else see this many issues on one wheel?
Any suggestions for a more permanent fix?
Silver 05
Supafly is offline
post #2 of 11 (permalink) Old 06-15-2017, 09:35 PM
System_Crash's Avatar
Quoted: 26 Post(s)
How are they failing? mopar parts? Is it possible you are over-torquing the axle nut?
System_Crash is offline
post #3 of 11 (permalink) Old 06-16-2017, 12:59 AM
04vipersrt4's Avatar
Quoted: 3 Post(s)
also add to that, are you using the axle nut washer? if your not using that, that'll as well when the nut is tq down pull the axle too far through the hub putting excess stress on the bearing.
Owner and fabricator of "Obryan lil Red Express Race Lights"
BW FMW 364.5, 3.5" full BST alum exhaust TG topmount T4 openscroll exhaust, DCR intake mani, 8.8 pistons, eagle rods 625 bolts, MAP machine straps DCR windage tray
Liberty input shaft, RT 3/4 fork, DCR Kevlar synchros, full blown twin pump -6 feed and return
BST tuned, stock computer daily driven
04vipersrt4 is offline
post #4 of 11 (permalink) Old 06-16-2017, 05:31 AM
Quoted: 43 Post(s)
I've had an issue with the same wheel bearing. I'm replacing mine for the 3rd time. This time around I'm doing both sides, hubs, lca, and tie rods. I'm wondering if I'm over torquing as well or the hub is bad. I heard a bad hub can blow a bearing. What parts are you using? OEM?
Nexus 6P using Tapatalk
04itr is offline
post #5 of 11 (permalink) Old 06-16-2017, 08:46 AM
SRTforums Admin
stowaway's Avatar
Quoted: 995 Post(s)
I always replace the hub when doing the bearings. Many owners found out the hard way many years ago that just doing the bearing will mean you're doing the bearing again in a year or two. Mopar or Timken Set49 bearings, whatever for the hub.
HybridKid, dodgezdad and 04itr like this.
stowaway is offline
post #6 of 11 (permalink) Old 06-16-2017, 10:22 AM
Quoted: 43 Post(s)
My experience.
From my understanding, Timken set49 is oem just without the mopar box.
ziggo0 and 04vipersrt4 like this.
04itr is offline
post #7 of 11 (permalink) Old 06-17-2017, 06:28 AM Thread Starter
Supafly's Avatar
Quoted: 2 Post(s)
Washer - Yes
OEM - yes
Over torque - No, looks like I am undertorqueing
I store it over winter, any issue for the bearing there?
Thanks for the help.
Silver 05
Supafly is offline
post #8 of 11 (permalink) Old 06-17-2017, 11:06 AM
ziggo0's Avatar
Quoted: 159 Post(s)
Originally Posted by Supafly View Post
Washer - Yes
OEM - yes
Storing is fine. Did you replace the hub(s) as well?
That bearing depends on that torque to stay together/work properly. How much under torque are we talking? How are you torquing your axle nuts?
Stone White 05 - Built Bottom End - Built Head - Arias - Eagle - BC - Crane - MPX - DCR - Borg Warner s257sx-e .82 AR T3 - e85 - tons of supporting mods
ziggo0 is offline
post #9 of 11 (permalink) Old 06-17-2017, 10:16 PM Thread Starter
Supafly's Avatar
Quoted: 2 Post(s)
Yes I will replace hub.
I used a torque wrench I had that goes only to 85 ft. I will get a bigger wrench.
Silver 05
Supafly is offline
post #10 of 11 (permalink) Old 06-17-2017, 11:20 PM
T4EaterJonny's Avatar
Quoted: 286 Post(s)
Garage
Its pretty fucking crucial that the halfshafts/axle nuts be torqued to the specified amount. The S2000s from the factory came with axle nuts which were undertightened and people had rear wheel bearing failures. C5 corvettes used to be 112 lbs but had a service bulletin and now its 160lbs plus locktite. The srt4 is 180. Yes... 180. 150 stood out in my head because that's all a harbor freight torque wrench goes to. Yes I went out and bought a better one that does 250+ now.
Torque Specs for R&R Transmission
ziggo0 likes this.
Big wheel stage 3. fresh motor. 151k on body. Will be repainting soon pop my hood red.
BC rods, JE pistons stock 8:1 .020 over, BS delete.
Sways & STbraces, coilovers valved by Feal, DIY solid control arms, wannabee racecar alignment.
T4EaterJonny is offline
post #11 of 11 (permalink) Old 06-19-2017, 05:45 AM Thread Starter
Supafly's Avatar
Quoted: 2 Post(s)
Well that explains a lot.
New torque wrench to 250 on order.
Silver 05
Supafly is offline
User Tag List
Linear Mode Linear Mode
