» Tire Upgrade Garage
Old 04-25-2008, 07:56 AM   #1 (permalink)
Member Number: 40145
Default 3rd gear kick out ?!
hey guys i have a pretty much stock 04 srt4 and im have a problem with 3rd gear, when im coming down through the gears ill put it into 3rd and release the clutch and occasinally it will kick it out of gear into neutral ( theres no loud sound or any thing and the car is fully in gear) The frist time it happend i figured well maybe i didnt have it fully in gear but the next time i know it was fully in gear. Any one else having a similar problem or know what would cause this ? any feed back would be great. thanks guys
beerpongchampion is online now   Reply With Quote
Old 04-26-2008, 11:14 AM   #2 (permalink)
Member Number: 10209
I've had same issue for a while now, can't figure out what it is. And some times it grinds as it kicks it out of gear. for answers
-AGP-Blitz-ClutchMasters-Engine Run up-E.D.-JLM-HKS-Hotchkis-MSD-Turbo XS-Walbro-
mark2685 is offline   Reply With Quote
Old 04-26-2008, 11:23 AM   #3 (permalink)
Member Number: 9051
Trader Rating: (15)
Yup... I have the same issue. What what I can tell it is the clip for the 3rd gear synchro..... if you look around, you will see how many guys have broken theirs... it seems as though it gets a little out of whack at times... and causes you to be unable to downshift into third (thats how mine is). How, that being said, many guys that replace the fork when they are doing the clutch have this go away... so chances are this is because the selector isn't being pushed up enough and is catching the clip....
pphilps is offline   Reply With Quote
Old 04-27-2008, 02:50 PM   #4 (permalink)
pumpkin05's Avatar
Member Number: 54667
the same thing happened to my 05 srt-4 and the dealer replaced my synchros. Was good after that.
pumpkin05 is offline   Reply With Quote
Old 04-27-2008, 02:57 PM   #5 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
Trader Rating: (15)
new syncro and fork, because your in there and it's a motherfukR, to open again!!!! Do both, enjoy butter smooth shifts into 3rd gear again. I had to rebuild mine's with a new syn & fork, after about 25 bottles of nitrous WOT shifts, because I'm a mad man!!!!! Holla!!!
OK, stg3 toys, Mpx3", MaxxFab 3"02, Samco's, Injen Ntake, Tbolts, Mp Clutch, Bov, STS, NX Nitrous kit, HOM junky................
The peep show has begun....
Soon, forged JE .020 8-1, Eagle Rods, No Balance Shafts, ARP fasteners, UD pulley.........MotherFuker, I've lost my mind!!!!!! Deepend has Arrived!!!!
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 04-28-2008, 12:58 AM   #6 (permalink)
pumpkin05's Avatar
LOL. I like your style. Any power numbers? From your sig. that looks like a undefeated set-up.
Old 04-28-2008, 02:05 AM   #7 (permalink)
eviilboy's Avatar
Member Number: 23842
Trader Rating: (17)
Yeah, basically you're screwed.
Mine started doing that about 10k miles ago.. and finally went boom. I can no longer downshift into third unless I perfectly rev-match.
Getting my tranny rebuilt tomorrow.. YAY.
eviilboy is offline   Reply With Quote
Old 04-28-2008, 02:13 AM   #8 (permalink)
SNOOPALOOP's Avatar
Member Number: 29605
yep, mine is f'ed up with same problem.
SNOOPALOOP is offline   Reply With Quote
Old 04-29-2008, 04:12 PM   #9 (permalink)
my_little_srt's Avatar
Member Number: 41179
Apperantly this is a defect on our cars......But DCX has faiiled to recognize it....
my_little_srt is online now   Reply With Quote
Old 04-29-2008, 04:14 PM   #10 (permalink)
Member Number: 63534
how much is a 3rd gear syncro?
Drastic_Said is offline   Reply With Quote
Old 04-29-2008, 11:35 PM   #11 (permalink)
Trader Rating: (15)
Smile
I have never dynoed my car, just too lazy. The sig is in the works, it's not done yet. But I'm boring it .020 8-1 JE's with Eagle rods. Should be a 2.5, fresh new stg3 turbo, stock head & probably cams. I have nitrous, and probably plan a 4 nozzle, and bigger shot. I can't afford cams & a ported head, but the foundation for the future has been set. That and the fact I no longer have balance shafts, and a underdrive pulley. The car should rev alot quicker, we'll hopefully see in 7-10days. The block, bedplate, pistons & rods are now at the machine shop. Then once I get it back 7-9hours later, I'll be driving it.
Old 04-30-2008, 07:04 AM   #12 (permalink)
will you let us know how much that runs you
Old 04-30-2008, 03:44 PM   #13 (permalink)
05BlackSRT's Avatar
Member Number: 31129
I have had a god awful problem with my tranny. It started grinding when it had about 8k on it..they rebuilt it, or so they said.. then again in about 10k more miles it did it again...dodge fixed it again..and again at about 30k it did it again and they fixed it again and voided my warranty..then I had to pay $1080 to get it fixed..and what they told me at my friends place that fixed it is..instead of rebuilding it or changing both the syncros and shift fork..they were just taking off the section they needed and replacing the shift fork..and the syncro was bent so it kept tearing up the shift forks..
-Tein S-Tech Springs
-AGP WGA
-Turbo XS MBC
-3" Cat-delete Downpipe
-K&N CAI
-Apexi Turbo Timer
-Greddy Type RS Blow off Valve and Charge Pipe
-5% Tint
-Xenon Visions 8000k HID's
05BlackSRT is offline   Reply With Quote
Old 05-01-2008, 10:55 AM   #14 (permalink)
Member Number: 53402
My transmission did the same thing 05 srt-4. I got it replaced with a BRAND NEW transmission Aug 2007 35,348 miles.
Now 8 months later it's doing the same thing again 41,880 miles. They are warrantying the Transmission AGAIN because 12 month/12,000 miles warranty. I will get a BRAND NEW Transmission.
8 months and 6,500 miles apart. they tried telling me that my rear tires were bald because i was beating on the car LOL
I had those tires for almost 2 YEARS now. Just bought 2 new ones for the front. Jackasses though they are giving me no other hassel and replacing my junk trans with a BRAND NEW one.
orangesrt-4 is offline   Reply With Quote
Old 05-01-2008, 11:21 AM   #15 (permalink)
BluFlame's Avatar
Member Number: 8399
Had the same problem for a while and finally while on a fun run a hour away from home my tranny broke and was stuck in 4th gear. Made it home after driving a hour in 4th gear at 60 mph. Opened up my tranny and found my Shift fork broke! Synchros looked fine. Changed the shift selector only and voila!! Can down shift into 3rd again w/ no grinding or kicking out at all.
It could either be the synchros, retaining clip or shift fork.
ZHP Built & Tuned
BluFlame is offline   Reply With Quote
