umm not so sure on ur method there.... haven't seen that one. Not sure if it would work well because ur working with a path tool and a selection tool... 2 totally different approaches.
I use the "magic selection tool" for much of my selection needs. I adjust tolerance as needed for fine tuning the selection.
Basically hold shift to add to ur selection if you mess up and added to much you back up, adjust tolerance and try again. Once done you can fine tune selection by inverting selection to remove pixels that you don't want and then switch back to normal (invert again) to add pixels that you might have missed. Once you have the selection you want you can easily change color by adjusting hue/saturation.
There is a trace feature that you can use too... i have had mixed results with it but it works well on high contrast images/selections.
