Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums 3 > NY/NJ/PA
Old 03-23-2008, 07:13 PM   #1 (permalink)
low4me's Avatar
Member Number: 53058
Default need help car wont start help asap
i need help just got done putting in the lower moter mount every thing went well took it around the block came back and now the car wont start just makes a clicking noise and a humming/buzzing sound checked the starter its good tried jumping it still does the same thing what could be the problem i have no clue help me
low4me is offline   Reply With Quote
Old 03-23-2008, 08:47 PM   #2 (permalink)
Member Number: 41469
Humming/buzzing might be the fuel pump which would be normal. The clicking sounds like a bad starter solenoid. Sometimes the starter can jam on the flywheel. Try rolling the car in nuetral and bump the clutch (to free the starter if it is jammed on the fly wheel), its a long shot.
How do u know the starter is good? Did you run power directly to it?
Make sure all connections to the battery starter and ground are good.
Good luck.
bracket_race is offline   Reply With Quote
Old 03-23-2008, 09:57 PM   #3 (permalink)
low4me's Avatar
the buzzing and humming is when i turn the key to start it after the pump hum gos off but i will try move it with the clutch i took the starter to auto zone and they said it was good it passed thanks for the info
Old 03-24-2008, 10:55 AM   #4 (permalink)
Member Number: 41218
Default battery
check your battery it might be shot. has happened to me several times.check youf fuses as well.
reysrt4 is offline   Reply With Quote
Old 03-24-2008, 06:17 PM   #5 (permalink)
topofnewyork's Avatar
Member Number: 1056
i agree happened to me too with a dead battery
TopOfNewYork
NY SRT CREW
topofnewyork is offline   Reply With Quote
Old 03-25-2008, 07:09 PM   #6 (permalink)
low4me's Avatar
Default battery
yup it was the battery i just bought the red top opptium dec 07 and it already had a bad cell
Old 03-26-2008, 01:42 PM   #7 (permalink)
Member Number: 1056
Your welcome good to see you are back up and running
Old 03-26-2008, 01:48 PM   #8 (permalink)
Member Number: 62176
when my car wont start. . . THAT is what i pray for lol or to be out of gas, theyre those things that everyone says to check when you know it cant be...but when it is...what a great feeling
atarh001 is offline   Reply With Quote
Old 03-26-2008, 01:59 PM   #9 (permalink)
dbowling's Avatar
Member Number: 61677
That is pretty quick to die for quite an expensive battery. I'm sure it was still under warranty though right?
dbowling is offline   Reply With Quote
Old 03-29-2008, 10:20 AM   #10 (permalink)
low4me's Avatar
thanks for all the info yea the bat was 190$ at advance autoparts and they gave me a new one but i had to get a bat to get to the store but thankfully that was all it was and now i have a 190$ battery as a back up
Page generated in 0.15985 seconds with 11 queries
