Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > Clutch Masters
Old 09-12-2006, 06:14 PM   #1 (permalink)
Member Number: 21175
Trader Rating: (13)
Default Ouch!! is there an warrany??
Im going to get some pics to show you guys the damage. I got a CM stage 4 6 phuck about 300 miles on it That disinigrated on me last week. shop man said it just came apart, putting a hole in my bell housing
My question is, do they have any kind of warrany?? It was install by a certified Transmission shop. I only have about 350 on the bottle. THis is nuts i just spend 1000 bucks on this clutch with install. Any help wanted!!
rockbottm is offline   Reply With Quote
Old 09-12-2006, 06:24 PM   #2 (permalink)
Tex
Tex's Avatar
Member Number: 3622
now im no clutch expert...i have only dealt with a dozen or so srt4 clutches, but i would say that a destroyed clutch wouldnt grab, it wouldnt take out your bell housing. unless the pressureplate itself broke, which is unlikely
it sounds to me like you are a victim of the "clutch bolt issue" that plauges the srt4 community. this is common if you reuse factory hardware, and is caused by a clearance issue between the clutch and the flexplate. the flywheel shows definite signs of contact between the two. a dodge engineering issue that they of course deny. it sounds like the bolts came loose and went boom
i always recomend replacing the hardware when doing a clutch. its cheap insurance. and i, myself, replaced my flexplate as well. why risk it, its only $80 and no extra work to install. cheap insurance if you ask me
so what i am saying is that it sounds like installer error and not CM's issue...but i could be wrong. post pics of the pressureplate/clutch. lets see what exactly failed.
-Soren Kierkegaard
Tex is offline   Reply With Quote
Old 09-15-2006, 11:01 AM   #3 (permalink)
clutchmasters's Avatar
Member Number: 24176
We do have a 90 day warranty, and in most cases even if you are past the 90 days we will still replace/repair your clutch if you send it in to our techs and we find that it is a case of manufacturer defect.
Travis Booher
Clutch Masters, Inc.
www.clutchmasters.com
clutchmasters is offline   Reply With Quote
Page generated in 0.15088 seconds with 13 queries
