Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > Clutch Masters
Old 09-14-2008, 10:19 AM   #1 (permalink)
Matt Tripp's Avatar
Member Number: 6739
Default FX600 / FX700 stroke to disengage?
I have your neon FX600 clutch in my first gen neon (NV T350 trans). I'm converting from the cable actuated setup to a Tilton master / Tilton hydraulic release bearing setup. The hydraulic release bearing has 0.500" of stroke, but they recommend 0.200" of clearance between the cylinder and the clutch diaphragm. This would leave 0.300" of movement against your diaphragm.
Would 0.300" be enough stroke to disengage the clutch? The contact diameter is 44mm (same as the TOB you provide). What is the minimum stroke to disengage? What is the maximum stroke before damage occurs?
Please advise!
1997 Neon ACR turbo "racecar"
2007 Trailblazer SS "daily driver"
Matt Tripp is offline   Reply With Quote
Old 09-14-2008, 10:28 AM   #2 (permalink)
NeonDan's Avatar
Member Number: 138
Trader Rating: (82)
hey matt can you take pics for a how to?
Old 09-14-2008, 02:42 PM   #3 (permalink)
Matt Tripp's Avatar
Member Number: 6739
I have a lot of pics in my project log over on neons.org:
www.neons.org • View topic - Project Neon 2008 - Tilton HTOB & AEM Coil-On-Plug Install
Old 09-19-2008, 11:41 AM   #4 (permalink)
clutchmasters's Avatar
Member Number: 24176
Please advise!
I am waiting for my tech to get me an answer on this, I will let you know asap.
Travis Booher
Clutch Masters, Inc.
www.clutchmasters.com
clutchmasters is offline   Reply With Quote
Old 09-19-2008, 03:28 PM   #5 (permalink)
I just got off the phone with Luis, and he mentioned that he already spoke with you. Anyways our twin requires 250 thousandths throw, so a pedal stop is recommended to protect from over throwing the diaphragm. Hope that helps.
Old 09-22-2008, 07:39 AM   #6 (permalink)
Matt Tripp's Avatar
Member Number: 6739
Yep, I spoke to Luis..
For the record, he stated that 0.400" of throw would over-center the diaphragm. Based on the stroke of my HTOB, and the gap that exists at rest, that would never happen.
Old 09-23-2008, 03:15 AM   #7 (permalink)
Member Number: 42189
If I am reading this right...Does that mean it take 250 thousands(quarter inch) to go from fully disengaged to fully engaged?
13.775 @ 99mph at PIR
13.9 @ 101.2mph...We'll get faster yet.
www.moparmen.ca
SilverBeast is offline   Reply With Quote
Old 09-23-2008, 07:34 AM   #8 (permalink)
Matt Tripp's Avatar
Member Number: 6739
Actually it means it takes 1/4" of movement of the TOB to go from rest (engaged) to disengaged. Don't assume this translates to 1/4" of movement of the pedal (which I think you're thinking) - there are lever ratios and master / slave cylinder bore & stroke ratios to consider. The pedal moves quite a bit more.
Old 09-24-2008, 04:22 AM   #9 (permalink)
ah...that makes sense.
I don't have problems street driving my FX 700. It is a little rough and you really gotta do it right but it can be done. I have other issues with it though that I should take care of. I'll be posting a thread when I have more time.
Old 09-24-2008, 01:01 PM   #10 (permalink)
littlepvt's Avatar
Member Number: 3267
Trader Rating: (45)
Hey Matt do you know if the HTOB you will be using also fits a SRT-4 with a FX700?
On Order: Precision GT4094r, t-4 Pro Series manifold, 4in exhaust, 3in piping from turbo to TB, Avenger Pro-Mod head, 8 injector IM, DCR intercooler w/ 3in inlet and outlet, Dogbox
DCR: 2.6 over 40, Input Shaft, CP Ignition,
Mopar: Sway Bars, S3R CO, Ti Strut Bars, RCAs, Camber Plates
Rage-Tek: LCA, HTOB, Triple Fuel Pumps, 3/4 fork
ClutchMaster: Twin Disk
AEM: EMS w/ 3.5 BAR sensor
Boomba: All 3 MM
littlepvt is offline   Reply With Quote
Page generated in 0.16537 seconds with 13 queries
