Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > Clutch Masters
Old 11-10-2006, 08:31 PM   #1 (permalink)
Member Number: 39852
Default fx-400
ive got a fx-400 that has chattered while in neutral with the clutch pedal not pressed, since it was installed. i hoped it would go away, but it never did. it also has a chatter when letting the clutch out, making it annoying to drive. i kinda hoped it would go away, and then i tried ignoring it, but its driving me crazy. is there anything i can do or do i need to replace it?
DTEC-FCBC, DTEC Tuner Wideband, AGP Standard FMIC, AGP WGA, Perrin 3" turbo back Polished SS,
K&N Air Filter, NGK Iridiums @.040, Bottle Neck fix, 180 T-stat, Energy Suspension Poly Master kit, mopar stage 1 suspension, mopar blow off plate, AGP LHP, AGP Return Line Kit, Walbro 255, ClutchMasters FX-400 6-Puck w/ Steel flywheel
windoz05 is offline   Reply With Quote
Old 11-10-2006, 08:42 PM   #2 (permalink)
AdvanSRT-4's Avatar
Member Number: 12791
Trader Rating: (57)
I think it's normal on that clutch. Live with it I gess.
AdvanSRT-4 is online now   Reply With Quote
Old 11-11-2006, 10:34 AM   #3 (permalink)
clutchmasters's Avatar
Member Number: 24176
It is normal for some extra noise with a race type of clutch, the noise at idle may just be the gear rattle that has always been there but is now transfered through the clutch even more because a performance clutch does not have plastic dampers to keep the noise levels down. If the noise is louder than you think it should be then check all of you mounts and/or flywheel bolts. Check this thread also..
Interesting find with loud clutch chatter
If you want to send it in, we would be happy to inspect it for you. Just let me know.
Travis Booher
Clutch Masters, Inc.
www.clutchmasters.com
clutchmasters is offline   Reply With Quote
Old 11-12-2006, 10:39 AM   #4 (permalink)
ccrochet's Avatar
Member Number: 32748
i recently purchased the fx 400 and i was wondering if you could advise on which disc to use, the 6 or 4 puck. it is my daily driver but i will be upgrading to a big turbo soon and it was necessary. will the clutch and flywheel combo help out much at the track? some people say it won't make that much of a difference.
ccrochet is offline   Reply With Quote
Old 11-12-2006, 07:04 PM   #5 (permalink)
2004NeonSRT4's Avatar
Member Number: 4577
Trader Rating: (44)
6 puk, still will chatter
2004NeonSRT4 is offline   Reply With Quote
Old 11-12-2006, 07:34 PM   #6 (permalink)
ccrochet's Avatar
that's what i figured but is it terrible or not too bad? i'm just wondering if my girlfriend will still ride in my car!
Old 11-12-2006, 08:26 PM   #7 (permalink)
Member Number: 4577
Trader Rating: (44)
it only chatters when the car is in neutral with the clutch out, other then that its quiet. but it does sound like the car has a bad valve tap when it is chattering
Old 11-13-2006, 07:29 AM   #8 (permalink)
i did check the alignment and it seems fine.
the chatter isnt that loud, if the windows are up you cant hear it much. mine is just annoying because the car shakes when you start from a stop.
other than people trying to tell me i spun a bearing or lost a lifter of something when its idling in neutral....
Old 11-13-2006, 10:00 AM   #9 (permalink)
The 6-puck will be slightly less aggressive and is great for daily driving and will still hold your power at the track. It will help out at the track because the clutch will not slip and the aluminum flywheel will allow you to rev much quicker.
Old 11-13-2006, 05:10 PM   #10 (permalink)
ccrochet's Avatar
thanx. i appreciate it. now i just have to wait for it to get to my house.
Old 12-01-2006, 09:38 AM   #11 (permalink)
lilturbododge's Avatar
Member Number: 24594
i have a loud tapping sound, but that is cause my pcv is gone, and i have yet to replace it....if the power is still there, then its not the motor, it is something else, where is the sound at....i would look around for other items....
Good-bye pistons, Hello Rotary
lilturbododge is offline   Reply With Quote
Page generated in 0.15972 seconds with 13 queries
