Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > Clutch Masters
Old 04-26-2006, 11:56 AM   #1 (permalink)
psi chick's Avatar
Member Number: 2363
Default cm s4 6pk question....
ok so i have a question about what's going on with my clutch (if that's even the issue?). i have the s4 6 puck w/aluminum flywheel. it was installed at n2mb a number of months ago. everything was good for a while, however now i'm having some issues. the problem is that i can't get into gear at high rpms. now this isn't a big deal driving on the street, and i don't really even notice an issue there, but at the track this is a major problem. i have to let the rpms drop back under 4k to get into gear. i had this issue once before, and it turned out that my flywheel had broken into two pieces. i'm hoping that it's not the same issue as it's a brand new aluminum flywheel. any thoughts?
thanks!
psi chick is offline   Reply With Quote
Old 04-27-2006, 02:15 PM   #2 (permalink)
clutchmasters's Avatar
Member Number: 24176
thanks!
Honestly I don't know what the problem is.. We would have to have a look at the clutch to determine if the clutch is the problem or not, it could be a number of things. If you dicide to take the clutch out, you can always ship it to our main shop for inspection and rebuild if necessary.
Travis Booher
Clutch Masters, Inc.
www.clutchmasters.com
clutchmasters is offline   Reply With Quote
