Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > Clutch Masters
Old 07-05-2006, 02:47 PM   #1 (permalink)
Member Number: 15028
Default Clutchmasters S3 question
I bought a S3 clutch from you about a month ago and am yet to put it in as I'm hearing both good and bad about chatter and shifting issues. I know many people knock the modular design on the SRT-4 and opt for the separate flywheel and pressure plate combo for its reliability. I bought the modular design. Is there anything I should look for? Would a non-modular clutch be a better bet for less problems down the road? Should I worry about the center piece coming off and causing excess noise as I add more hp? Any insight would be appreciated.
NCNTRL516 is offline   Reply With Quote
Old 07-06-2006, 10:14 AM   #2 (permalink)
clutchmasters's Avatar
Member Number: 24176
You do not have to worry about the centering peice as we have been welding them on the steel flywheels scince about 2-3 months ago, and if you have the aluminum flywheel the centering peice is part of the flywheel it's self. As far as modular vs. non-modular, as long as you are not making more than 400-500 ft/lbs tq. you will be fine with the modular design. The main reason that we have done away with the older modular design is to eliminate the weak point, (stock flex plate), mainly because the high HP cars would warp the flex plate causing shifting issues.
So if you think you may be adding a lot of HP in the future it might be wise to go with a stage 4 in the new non-modular design, but if not I would stick with the stage 3 that you have.
Travis Booher
Clutch Masters, Inc.
www.clutchmasters.com
clutchmasters is offline   Reply With Quote
Old 10-17-2008, 12:39 AM   #3 (permalink)
sikwititxvodka's Avatar
Member Number: 61056
had that problem with flex plate so i said f*** it and bought the FW-SRT4-AL which is the clutch master flywheel the deletes the flexplate............ lil bit of chattering but good results
sikwititxvodka is offline   Reply With Quote
Page generated in 0.13148 seconds with 13 queries
