Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Clutch Masters
Old 03-12-2006, 09:11 PM   #1 (permalink)
Farani's Avatar
Member Number: 8429
Default Clutch Masters Stage 3 Light Pedal feel?
I just installed my Stage 3 clutch on a brand new engine so I haven't started it yet, I'm still putting everything together on it. But the pedal feel on the clutch is very light. Lighter than stock. Is this normal? Or did I do something wrong during the install? Do I need to bleed the line? From Searching it sounds normal. But I just want to be sure. Thanks.
Farani is offline   Reply With Quote
Old 03-12-2006, 10:25 PM   #2 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (552)
God I hope this doenst become a problem with the stg 3 clutches.
Old 03-12-2006, 10:28 PM   #3 (permalink)
Farani's Avatar
Member Number: 8429
lol well that doesn't sound good. So this isn't normal? Everything is engaging fine. Pulling off the plastic cover on the tranny I can see the lever moving fine and the bearing engaging the clutch. It seems to be okay. I won't know until I start the car next weekend, but I just want to make sure.
Old 03-12-2006, 10:32 PM   #4 (permalink)
Farani's Avatar
Member Number: 8429
I also noticed I can shift the car into gear without the clutch engaged just as easily with it engaged. I haven't had my car running for 6 months now so I'm wondering if this is normal? I will say that if I'm in 5th gear and try to go in reverse it's locking me out of reverse so it seems to be okay in that respect. Just thought I'd throw that out.
Old 03-12-2006, 10:33 PM   #5 (permalink)
I have had that happen on a few occations with the same clutch install. The clutches started to slip on both of those installs. We bleed the clutch system, replaced all the hydralics and then pulled the unit apart to check the install and put it back together. After 5K miles it started to slip when we hit over 400 torque. I dont know why or if there is a problem with them. Go to the drivetrain section and you can see that there are some problems right now with this paticular clutch over the last few months.
Old 03-12-2006, 10:37 PM   #6 (permalink)
Farani's Avatar
Member Number: 8429
here's something i found in the clutchmasters forum:
Quote: Originally Posted by clutchmasters
This is perfectly normal! A lot of drivers say that this unit even feels lighter than stock. This is the way we manufacture our pressure plates, we move the fulcrum point to get more leverage enabling the clutch to have a soft pedal feel even when we add a lot of pressure to the pressure plate.
Break it in for a couple hundred more miles then hammer on it and it will grab HARD.
Old 03-12-2006, 10:42 PM   #7 (permalink)
Farani's Avatar
Member Number: 8429
Okay after reading some here it sounds like pumping the clutch a lot should help, which I did, but it didn't seem to do a lot. Adjusting the pedal was also mentioned, which crossed my mind too. I guess I'll just have to wait and see until I get it running.
Old 03-13-2006, 08:21 AM   #8 (permalink)
clutchmasters's Avatar
Member Number: 24176
Yes, this is completely normal for the stage 3. We re-engineer the fulcrum point on the casting which lets us use leverage to our advantage to get the clamping force without the added pedal effort.
Travis Booher
Clutch Masters, Inc.
www.clutchmasters.com
clutchmasters is offline   Reply With Quote
Old 03-13-2006, 08:21 AM   #9 (permalink)
04TurboSRT's Avatar
Member Number: 12748
good luck.. on slicks, my cm s3 slipped bad at the strip into 3rd gear .. the light pedal is normal though..
S3RToys, E-Manage, Walbro 255, CTI HS pipe, JMB L/UPP w/ 1gdsm bov, DCR oil mod, AGP Race FMIC, AGP WGA, BWoody CBar, Kinetic 60mm TB, ExHone ITM, Injen SRI, CMist W/I, MaxxFab O2H, Mopar CatD/B, Prothane Inserts, PTPcheckvalve, 8mm wires, ClutchMasters Stg4 w/Alum Fly, slow4drSTS, DCS F/R STBs, PT/ACR sway/tension bars, Revitup TractionBar, Eibach Coilovers.
1/4 mile: 11.93@115mph on M&H 24.5" slicks (1.85 60ft) & HOM drop in 4th
04TurboSRT is offline   Reply With Quote
Old 03-13-2006, 10:15 AM   #10 (permalink)
Farani's Avatar
Member Number: 8429
Okay, that's all I wanted to hear. I won't be taking my car to the track at all so I'm not worried. It's a daily driver. If I was going to track it a lot I would have gone with stage 4. But 40+ miles a day in stop and go traffic, I figured stage 3 was the way to go. Thanks for the fast response!
Old 03-13-2006, 10:41 AM   #11 (permalink)
Your welcome! This is the perfect daily driver clutch.
Old 03-29-2006, 08:57 PM   #12 (permalink)
SupeRfasT-4's Avatar
Member Number: 24103
Trader Rating: (20)
I have the light pedal feel also and i like it, easier to drive it.
Nikon D80 Photog
SupeRfasT-4 is offline   Reply With Quote
Old 03-29-2006, 09:00 PM   #13 (permalink)
SRTforums Veteran
Kustomatix's Avatar
Member Number: 18578
Trader Rating: (112)
About to put it on my car.
Kustomatix is offline   Reply With Quote
Old 03-30-2006, 06:13 PM   #14 (permalink)
Farani's Avatar
Member Number: 8429
Mine started slipping bad today.
Old 04-06-2006, 10:46 AM   #15 (permalink)
KeyboardCommando's Avatar
Member Number: 38988
Trader Rating: (15)
That sucks...... I just got my CM Stsg. 4 4-puck put in and has about 90 miles on her...nothing but a little ticking sound (which is normal im sure ) and I also just installed my GT3076R kit and the clutch holds fine so far at 12psi (stock fuel system) and only up to 4500rpms (dont wanna go any higher...
KeyboardCommando is offline   Reply With Quote
