Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Needswings.com
Old 03-03-2008, 09:55 PM   #76 (permalink)
ndswngs's Avatar
Member Number: 5729
Trader Rating: (338)
you may need more then 6 ft, we use these bundles when we install so we can make sure all the colors match, there $11 for the package at our local elelctronics store
ndswngs is offline   Reply With Quote
Old 03-03-2008, 10:04 PM   #77 (permalink)
Member Number: 11814
Trader Rating: (99)
^^^^nice^^^^^ I spent too much time and money buying the stupid little spools of wire at $3.50 a pop. That bag for $11.00 would have been worth it had I known about it.
Old 03-03-2008, 10:08 PM   #78 (permalink)
Jpdriven's Avatar
Member Number: 47369
thats freakin awsome, nuttin like doin a clean installtion
if i cannot find it locally, i may have to PM you for a bag of weed....(ahem)....i mean wires****
Jpdriven is offline   Reply With Quote
Old 03-12-2008, 05:49 PM   #79 (permalink)
Jpdriven's Avatar
ok..so i installed my zeitronix datalogger.....i used the boost and rpm options, i tapped in the tps as well, the lcd works perfectly, i see my readings very clear and the peak recall button works too. Now i cannot seem to be able to connect to my laptop,
my zeitronix came with a data splitter and a extra data cable(phoneline cable) along with a 9-pin adapter. Since my laptop has a 15-pin input(monitor input) it didn't plug in, so i removed the 9-pin adapter and plug the data cable straight to one of the COM ports, #3 to be exact, but i don't see anything when i open up the software, all i see is this, no graphs or nothing.
Old 03-12-2008, 06:27 PM   #80 (permalink)
ndswngs's Avatar
Member Number: 5729
sounds like you have the wrong port selected in the software, edit - settings - port selection
Old 03-12-2008, 06:29 PM   #81 (permalink)
ndswngs's Avatar
Member Number: 5729
wait, you plugged the phone line into a modem? if you dotn have a serial port on your laptop you will need a usb to serial adaptor cable and the data will then go in thru the usb port on the laptop, i can get you one of the adaptor cables from zeitronix or you can pick one up at a local compusa/bestbuy/ect..
Old 03-12-2008, 06:40 PM   #82 (permalink)
Jpdriven's Avatar
LMAO, yup..im afraid that was what i did....lulz......
omfg, i feel like such a a-hole...
I'll check my local electronics store tomorrow for the serial to usb adapter and if i cant find one then i'll give you a PM.
LOL @ ME trying to connect it to the modem....
thanx man.
Page generated in 0.15152 seconds with 11 queries
