Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Needswings.com
Old 06-21-2006, 06:11 PM   #61 (permalink)
RuizGT's Avatar
Member Number: 32437
Trader Rating: (15)
Quote: Originally Posted by danorth
Quote: Originally Posted by RuizGT
The one I bought from radio shack came with a cd with the driver on it.
I think I read your post and saw it worked right after. I will follow your lead and try just that.
turbojack: I appreciate your advise as well. I have contaced them and await their response. It is a driver issue. I cannot change the com port yet because the computer doesn't know what to do with the serial-usb cable. Once I get it figured out I will be able to use a more modern laptop. Until then I have to deal with a dying battery!
Weird, pick up a small power inverter from best buy, I think they're like 20 bucks, then just plug the laptop in and charge it if you need to.
Silver '04, Mods: Yes. Appeared in Modified Mag March 2008 issue on pg. 103. Yeah, behind the blue one.
RuizGT is offline   Reply With Quote
Old 06-21-2006, 11:48 PM   #62 (permalink)
Member Number: 38638
Trader Rating: (10)
Yeah, my brother gave me a power supply for the car, and I got the usb to work now (com 5). That was the trick there after getting the correct driver installed.
Today I ordered a Palm Vx with the goodies, a cable for it and the datalogger software from them. Yet another expensive day to have srt-itis!
160 Thermo/80% sts with Booger bushings/S1/S2 Inj/PTP WGA 21.8 ~ 14/Champion 570 (0.035)/Maxxfab 3" O2/V6 Needswings DP with elec flapper/3" cat back/Race inserts (zero wheel hop)/ Zeitronix wideband /Map clamp 4.2v/PTP 55mm TB/QW DF FMIC/fuel pump rewire
danorth is offline   Reply With Quote
Old 03-15-2007, 01:27 AM   #63 (permalink)
Beeznut02neon's Avatar
Member Number: 30643
So do you use all 12 wires?
And what wires go where? I have the instruction sheet from the forums but can't figure out wherer everything goes. Help would be great
IF YOUR NOT WITH US!!......YOUR BEHIND US!!!!
Beeznut02neon is offline   Reply With Quote
Old 03-18-2007, 11:13 AM   #64 (permalink)
ndswngs's Avatar
Member Number: 5729
Trader Rating: (336)
http://www.zeitronix.com/installatio...structions.pdf
ndswngs is online now   Reply With Quote
Old 03-19-2007, 09:05 PM   #65 (permalink)
Buy/Sell section Moderator
dojaman666's Avatar
Member Number: 3804
Trader Rating: (33)
can you hook the zeitronix to the dtec w/o and tach adapter?
Quote: Originally Posted by thepowertowin View Post
For a moderator, you're a dick and don't support the very forum that you work with.
All items for sale will use the proper format.
If you have any questions please see here:
http://www.srtforums.com/forums/f27/...elines-352468/
dojaman666 is offline   Reply With Quote
Old 03-24-2007, 04:34 PM   #66 (permalink)
okay I know where the wires go to. i have the install instructions. But what wires do I connect to on the car what wire goes to what wire on the car????
Old 03-24-2007, 05:26 PM   #67 (permalink)
ndswngs's Avatar
Member Number: 5729
im not sure i understand what your asking, did you read the install notes in the first post of this thread....
"Gray wire from Zeitronix (TPS) to orange/blue tracer wire (SRT-4 TPS)" ect...
the options you don't use don't hook up
so for the minimum you need....
pin#
1 red power YES
2 white NO
3 green rpm NO
4 orange boost NO
5 white/blue warning NO
6 yellow boost power NO
7 black ground YES
8 brown ground YES
9 purple narrowband output NO
10 grey tps NO
11 brown ground YES
12 blue input NO
Old 03-24-2007, 05:36 PM   #68 (permalink)
dj2
dj2's Avatar
Member Number: 28474
Trader Rating: (28)
I only needed the tach adapter for my e01 not the zietronix. I am not sure how the dtech works but the output on the zietronix is non-linear so there is a narrow range (from about 10.5-15.5) that the AFR's will be accurate IF you set the voltage/corrosponding AFR correctly. If you need the info pm me and I can go look at the proper settings for you.
dj2 is offline   Reply With Quote
Old 03-24-2007, 08:18 PM   #69 (permalink)
okay so Im don't need all 12 hooked up than. just them four that you said yes to is all I need than?
Old 03-25-2007, 02:03 AM   #70 (permalink)
ndswngs's Avatar
Member Number: 5729
zt2s do have a linear output
yes you only need the 4 wires for the minimum
Old 03-01-2008, 03:13 PM   #71 (permalink)
Jpdriven's Avatar
Member Number: 47369
ok, i think i have everything down.....
i have the boost and egt add-ons and the Tach driver....and according to the instructions in the first post, i wont be using pin # 2(white) 8(brown) and 9(purple) <--what are they for anyways??
i also have a mapclamp (dasmopar), i guess i am going to use pin# 12(blue) for that.
correct???
the only thing that confuses me is the "LCD display selection between boost, user and tps" .....i dont mind toggling the yellow button on the lcd screen to see the other readings..is that what this is about?????
Jpdriven is offline   Reply With Quote
Old 03-01-2008, 11:55 PM   #72 (permalink)
ndswngs's Avatar
Member Number: 5729
the yellow button is for peak hold. will be peak boost since you have that connected) not to toggle readings
#2 is an output to an engine management system
#8 i put to ground
#9 is an output to an engine management system
Old 03-02-2008, 12:00 AM   #73 (permalink)
Jpdriven's Avatar
#8 i put to ground
ohh ok, i thanx for clarifying that, guess i wont be using those three anyways.
everything looks pretty straight forward, do you know to what wire do i connect that #12(user input 0-5v) on my dasmopar mapclamp?
Old 03-02-2008, 12:23 AM   #74 (permalink)
ndswngs's Avatar
Member Number: 5729
umm, id have to ask lon what wire throws the signal from the mapclamp wires, im a bit rusty on that one sorry.
Old 03-02-2008, 01:01 AM   #75 (permalink)
Jpdriven's Avatar
lol, thats ok, it cannot be that hard to figure out, anyways,im gonna buy like 6ft of (corresponding color) wire of each wire that i'm running to the engine bay
which are six wires (3 for the boost, 1 for TPS, 1 for tach signal and 1 more for the mapclamp).
i plan on mounting the brain under the center console(just like the instructions say to) hopefully i remember to take pictures and then maybe i can post them here if you want.
