Old 06-21-2005, 11:59 AM   #76 (permalink)
Member Number: 25854
Trader Rating: (62)
Like one of these AP-13SK
http://www.keyence.com/products/sens...ications_2.php
Probably too expensive, though.
What about an oil pressure sender? Those work up to some high pressures and should be compatible with water...
I believe they have a simple resistive output. Just add a known precision resistor and a voltage source and you'd have a voltage output proportional to pressure.
What about it?
Old 06-21-2005, 12:02 PM   #77 (permalink)
Trader Rating: (62)
or here:
http://www.ti.com/snc/pdf/auto-ap2.pdf
Old 06-21-2005, 12:58 PM   #78 (permalink)
omniphil's Avatar
Member Number: 538
Yeah, you'll need some sort of pressure transducer, those usually arent too cheap tho...
---This is my kung fu, and it is strong---
---The surgeon general never said anything about smoking the competition---
01' Neon ACR - Turbo (2650lbs - 242whp/226tq) R.I.P. -->http://home.comcast.net/~omniphil/acr/<--
04' SRT-4 Lightweight (2680lbs - 291whp/338tq) -->http://home.comcast.net/~omniphil/acr4/<--
08' Yamaha R6S
omniphil is offline   Reply With Quote
Old 06-21-2005, 01:17 PM   #79 (permalink)
Back-n-Black's Avatar
Member Number: 15950
Trader Rating: (42)
What about it?
What would you use the output for? So you go threw all this to get a voltage output that is proprtional to the injection pressure....... what does this do that a pressure gauge wouldn't? Or are you talking about making an output for data logging purposes?
Randy
Back-n-Black is offline   Reply With Quote
Old 06-21-2005, 02:29 PM   #80 (permalink)
SRTforums Veteran^2
xxx_srt's Avatar
Member Number: 8181
I am thinking he wants to add WI to this:
Open-source engine tuning hardware development
xxx_srt
xxx_srt is offline   Reply With Quote
Old 06-21-2005, 03:25 PM   #81 (permalink)
Trader Rating: (62)
Exactly, I want a digital pressure gauge for my control system.
I suppose I could also measure flow rather than pressure. They will be related during normal operation.
The idea is to use the flow measurement to adjust the motor drive, helping to provide a consistent and repeatable flow. Plus some more checks that your system is working.
I don't want to add anymore mechanical gauges to my car. Everything will feed into the engine control module and used for the control loops.
There will be a single LCD that will display status and measurements, if I want to look at them...
So, what about using an oil pressure sensor? They are cheap... $30 or so. Can anyone find specs on them? What operating range range they have?
Randy
Old 08-18-2005, 02:59 PM   #82 (permalink)
SRT&EM2's Avatar
Member Number: 22749
The kit im using uses a pressure switch on the pump and a solinoid controlled by a boost switch. So the lines are allways charged and the solinoid only opens at the boost level u set it to. So no lag time and no loosing the charge in the lines during vac.
SRT&EM2 is offline   Reply With Quote
Old 08-18-2005, 03:02 PM   #83 (permalink)
omniphil's Avatar
Member Number: 538
Unless the solenoid is right next to the nozzle, you will lose charge. Anything after the solenoid gets emptied...
Old 08-18-2005, 03:06 PM   #84 (permalink)
NeonDan's Avatar
Member Number: 138
Trader Rating: (63)
whos is that in your sig phil? ...wait i have her phone number i'll just call her up
727-512-9684 Need SRT4 help? Im a call away
Built by experts. Tested in the real world. ~ Mopar
Dont let the fact i drive Neons deter you, I have 8+yrs neon and 5yrs SRT4 experience.....god bless!
NeonDan is online now   Reply With Quote
Old 04-04-2006, 02:34 PM   #85 (permalink)
jpleasureking's Avatar
Member Number: 33798
Smile Devils Own WI
Devils own WI, with progressive controller. That setup will let your system start at 2psi of boost. Put your check valve directly on the nozzle to the brass fitting, which is the setup I use. It uses an electronic controller, which you might want to consider getting if you are getting that kind of lag. I run 21 boost spikes and 19-20ish to redline works prefect for me. That is on the stock turbo I might add, with port fueling.
jpleasureking is offline   Reply With Quote
Page generated in 0.27070 seconds with 11 queries
