Old 07-31-2009, 11:08 PM   #1 (permalink)
Member Number: 52407
Default Why mount nozzle before the IAT?
Just a thought but would mounting the nozzle after the IAT help hold HOM? Putting the nozzle before the IAT means it sees cooler intake temps, cooler intake temps means more timing, more timing means more knock.
7055 is offline   Reply With Quote
Old 07-31-2009, 11:13 PM   #2 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (23)
Makes sense.
WTB: 96-07 Nissan Pathfinder parts;
Hood
Left front fender
Left headlight
Radiator
Condensor
Bumper Cover
Grille
HCCAFan is offline   Reply With Quote
Old 08-04-2009, 03:08 AM   #3 (permalink)
I know somebody has an educated opinion regarding this
Old 08-04-2009, 03:40 AM   #4 (permalink)
Xx_R/T_xX's Avatar
Member Number: 18749
well i tryed both and saw a better afr when my nozzle was before the iat sensor.also my knock went down from 5kr to 1.5 by just changing the location of the nozzle
BIG TURBO!
Old 08-04-2009, 08:22 AM   #5 (permalink)
Member Number: 13142
I ran into this with my 50 trim setup, I ran it after the IAT so the timing wouldn't be increased with the colder intake temps. You got the right idea for sure. To add, I didn't want high timing since I'm running a 50 trim, so this helped keep my timing around 26-28 degree range vs 28-30 running before the IAT sensor.
M10 nozzle, D/O 250psi pump 100% methanol.
seltech is offline   Reply With Quote
Old 08-04-2009, 08:31 AM   #6 (permalink)
OrAnGe-SrT4's Avatar
Member Number: 29828
Trader Rating: (30)
I don't see why running the nozzle before the IAT sensor would hurt anything? More timing yes, but you're going to run meth which is going to increase octane anyways. You should be just fine depending on how much meth you run.
OrAnGe-SrT4 is offline   Reply With Quote
Old 08-04-2009, 12:59 PM   #7 (permalink)
Member Number: 38712
Yeah, now I'm lost. . . More timing is better, right? You guys are running knock sensors, so if the additional timing was causing knock, wouldn't it get pulled back?
Tjabo is offline   Reply With Quote
Old 08-04-2009, 01:02 PM   #8 (permalink)
This paints a little different picture though, because this looks like 3.5 degrees extra was getting pulled, which compares pretty closely with the timing advance gained through having the methanol cooling the IAT sensor.
BTW, what do you mean by better AFRs? Leaner?
Old 08-04-2009, 01:50 PM   #9 (permalink)
You reduced your knock count by 3.5 by changing the location of your nozzle from where to where?
Old 08-04-2009, 03:22 PM   #10 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
More timing on a smaller turbo is a good thing. Would I want 32* on an S256...probably not. Thus direct port
Quote: Originally Posted by KoldKill View Post
E1 is ethanol fuel (corn based) you need mucho larger injectors and a tune (I think?) to run it...
Old 08-04-2009, 04:09 PM   #11 (permalink)
More timing isn't always better because it means more knock. Yes it will pull back timing, its called the knock count, but it might also hurt your motor first. And if you have HOM then it will kick you out of hom.
Old 08-04-2009, 05:04 PM   #12 (permalink)
More timing isn't always better because SOMETIMES it means more knock. Yes it will pull back timing IF IT SENSES ENOUGH KNOCK, its called the knock count, but it might also hurt your motor first. And if you have HOM then it will kick you out of hom IF IT KNOCKS ENOUGH.
Maybe that is a bit better?
What you didn't say that I think is more true than most of this is that timing advanced beyond MBT is disadvantageous, even without knock. What I was hoping someone would post is that the SRT-4 engine is not knock limited with its low compression ratio, so the advance values in the tables are already optimized for MBT at true air temps.
Old 08-04-2009, 06:30 PM   #13 (permalink)
The PCMs also optimized for 100 + octane which isn't going to be in the tank.
I don't follow
Old 08-04-2009, 06:38 PM   #14 (permalink)
Hence, the water injection, right?
Old 08-04-2009, 06:54 PM   #15 (permalink)
What are you trying to say? So if you go past MBT timing it's not benificial, so what?
Page generated in 0.19594 seconds with 13 queries
