Old 08-22-2009, 09:51 AM   #1 (permalink)
turbojack's Avatar
Member Number: 11814
Trader Rating: (122)
Default Whose, who, what and where
It is a good time to do a complete listing of current water/alky injection manufacturers and their product. Specifications, capabilities and price range.
Active
Capabilities: Adjustable manifold pressure activation
Pump: Shurflo
Electronic Controller option:: not mentioned on site
Chemical compatibility: Water, Alcohol
Failsafe: not mentioned on site
Price range: US$750.00
Warranty: Not mentioned on site
URL: http://activeautowerke.com/cooling/main.php
EMAIL: aatuning@activeautowerke.com
AEM
Location: 2205 126th Street, Unit A Hawthorne Ca. 90250
Capabilities: Mainfold pressure activated
Pump: Shurflo
Electronic Controller option:: Onboard MAP sensor Pump speed controller
Chemical compatibility: Water, 50% Alcohol (recommened)
Failsafe:: water level sensor and power supply failure
Price range: US$390.00 - $570.00
Warranty: 12 months
URL: http://www.aempower.com/ViewCategory...CategoryID=120
EMAIL: emstech@aempower.com
Alkycontrol
Capabilities: Progressive delivery proportional to MAP sensor. Inline filter, metal fittings, and stainless steel braided lines.
Pump: Shurflo
Electronic Controller::Based on PAC module controlling pump speed to vary pressure
Failsafe: Failsafe Bi-colored LED works of pressure sensing, inline filter, metal fittings, and stainless steel braided lines.
Price range: US$425-495
Warranty: 1 year unconditional and 100% methanol URL: http://alkycontrol.com/
EMAIL: Online form or phone
Aquamist
Capabilities: Static flow, mappable, fuel injection duty cycle tracking, ECU interface and map switching
Pump: Own design - magnetic piston type and 150W/125psi by-pass Shurflo pump NEW
Chemical compatibility: Water, Methanol. 100% methanol and 10 to 20% nitromethane withteflon seals: supply on request
Failsafe: Dash Flowmeter or fulltime monitoring via signal error comparator circuitry, boost control and map switching output.
Price range: US$585.00-3000.00+
Warranty: 12 months
URL: Water injection systems, Methanol injection systems : Aquamist
EMAIL: info@.aquamist.co.uk (sales enquiry), richard@aquamist.co.uk (technical)
Aquastealth
Capabilities: Static flow, Pressure switch activated inline solenoid.
Pump: Shurflo
Chemical compatibility: Water, Methanol, isopropyl and ethanol.
Failsafe: unspecified
Price range: US$239.00
URL: Computer Water Cooling, Automotive Water Injection, Aquarium Chillers and Pumps,
EMAIL: sales@aquastealth.com
Coolingmist
Capabilities: Progressive, Static flow – single or dual stage
Electronic Controller: Digital Programmable "progressive" style controller capable of 2d Maping. Optional Commander for datalog, digital display.1-30 psi sensor or 4-120 psi.
Pump: Custom Shurflo
Chemical compatibility: Water, 100% Methanol safe (EPDM Seals)
Failsafe: hi/lo system pressure switch to detect loss of pressure or clogged jet. Upcoming Vari-Safe Smart Injection
Price range: US$299.95 to $999.95
Warranty: 1 Year Warranty
URL: Water Injection, Methanol Injection, Alcohol Injection Systems | Coolingmist
EMAIL: coolingmist@comcast.net
Devilsown
Capabilities: Static flow, PWM pump speed control option
Electronic controller option: 0-5v (selectable scales 2 bar,3 bar,voltage) – pump speed control . Price US$125.00
Failsafe: over-current sensing
Price range: US$205.00-305.00 + MAP sensor
Warranty: One Year Limited
Water injection : alcohol-methanol injection | DevilsOwn
EMAIL: sales@.alcohol-injection.com (sales inquiry), support@alcohol-injection.com (technical)
Hydramist by Element Tuning
(Work with Hydra EMS only)
Capabilities: Full 3D hi-res mappable, inbuilt failsafe.
Electronic controller: Element Hydra stand-alone EMS.
Pump: Shurflo (150W), with 125psi internal by-pass
Chemical compatibility: Water, Methanol, Ethanol, Iso-propyl
Failsafe: DDS3 flow sensing system - auto map switching via DDS3 v7.
Price range: US$799.00 not including Hydra EMS
Warranty: Not yet specified
EMAIL: phil@elementtuning.com
URL: Element - Detecting Flash
EngineRunup
Capabilities: Static flow and two stage. Solenoid controlled
Electronic Controller: Call
Pump: Shurflo
Failsafe: two pressure switches to detect clogged jet (250psi) and low tank level option
Price range: US$189.00-359.00
Warranty: 90days -Limited
URL: www.enginerunup.com
EMAIL:info@enginerunup.com
Gaseous Intercooling TM
Pump: Flojet
Failsafe: Flow switch
Price range: $395.00-540.00 basic to Standard Plus (with solenoid)
Electronic flow controller: US$195.00 sold as an optional extra
Warranty: 90 Days
URL: BlowerWorks:::
EMAIL: greg@blowerworks.net
Hyper-drive
Capabilities: Mappable pump speed controller
Pump: Shurflo
Failsafe: low water level sensor.
Warranty: not mentioned on site
URL: Digital Alcohol Injection
EMAIL: resolution@hyp-drive.com
Labonte Motorsport
Loves Park, Illinois 61111 UDA
Capabilities: Static flow, PPS based on IDC and MPS
Pump: Aquatec
Chemical compatibility: Water, Alcohol (call)
Failsafe: Turbine flow sensor based
Price range: US$295.00 - $700 + add-on optional extra
URL: Labonte Motorsports high performance methanol injection systems
EMAIL: On site fill-in form
Perrin
Capabilities: IDC tracking - PPM pump control (progessive)
Pump: Electrionmagnetic piston pump
Failsafe: low water level sensor and real time flow tracking
Price range: US$749.99
Warranty: Terms and Conditions on Site
URL: Perrin Performance - Welcome
EMAIL: Sales@perrinperformance.com
RSR
Capabilities: Static flow, Port injection
Pump: Shurflo
Failsafe: water level switch
Price range: US$185.00-345.00 + MAP sensor
Warranty: call
URL: RSR Water Injection Calculator
SMC
Capabilities:Progressive controller
Electronics controller option: - control pump speed to vary flow.
Pump: Flojet/Rotary fuel pump
Chemical compatibility: Water, Ethanol, Methanol, and Isopropyl alcohol types (recently updated)
Failsafe: tank level sensor at present.
Price range: US$399.00-499.00
Warranty:90 Days
URL: Welcome to SMC Enterprises
EMAIL:schlupsa31@mchsi.com
Snow Performance
Capabilities: Static flow, solenoid
Electronic controller option: Progressive pump speed controller +$129.00
Pump: Shurflo
Failsafe: flow switch based. $99.00
Price range: US$185.00-439.00 (MAF vs Pump speed)
Warranty: limited option by vendor
URL: Snow Performance: Home
EMAIL: mbsnow57@msn.com
Spearco Water Injection System
Location: Top-End Performance, N.Hollywood, California.USA.
Pump: Not specified
Failsafe: Not specified
Price range: US$219.00
Warranty: Call
URL: http://www.h2oinjection.com
EMAIL: topend@racetep.com
TTP Engineering
Capabilities: Static flow, Progressive controller –sold separately(PWM pump)
Pump: Shurflo Based
Control option: pressure switch, TPS or MAP (0-5v selectable)
Failsafe:upgrade path available
Price range: from US$299.00(base) + accessories
Electronic Controller: Variable injection rate controller now available
Warranty: Call
URL: TTP-Engineering : Mitsubishi Evo Performance
EMAIL: online form filling
Underdog Racing Development
Pump: 150W/125psi by-pass Shurflo pump
Failsafe: Dash Display Flowmeter, boost control and map switching output.
Price range: US899.00 ('till 31st Dec 06)
Warranty: 12 month? (please confirm URD)
URL: Underdog Racing Development
EMAIL: Info@urdusa.com (sales inquiry)
Page generated in 0.21771 seconds with 13 queries
