Old 10-11-2007, 12:34 PM   #1 (permalink)
California Moderator
Mana4real's Avatar
Member Number: 25021
Default Where are you tapping for power for your W/I system?
I am curious where everyone is getting power for their W/I system. I posted in the Import Image section and haven't had a single reply in two days. Are you guys giving it constant power at the fuse box and then letting the boost switch close the circuit? Or are you running it to key on current from somewhere? If so, what circuit are you wired off of?
-Matt- -SCT Tuned- By Yours Truely
05 SRT-4 Stage 3 47lb FP Green
Old 10-11-2007, 08:38 PM   #2 (permalink)
rasp's Avatar
Member Number: 56076
Constant power for me comes from the battery and my 12v ignition wire source comes from the red wire on my tach driver under the hood.
Old 10-11-2007, 10:29 PM   #3 (permalink)
Member Number: 8193
I put this up a few times... Here it is. coolingmist questions and answers...ask them here!
Old 10-12-2007, 12:16 AM   #4 (permalink)
Chino7385's Avatar
Member Number: 30157
Trader Rating: (21)
Fuse holder:
*98 Neon R/T:Too Many mods
*00 Celica GT-S:I/E,STS,S-Tech's,S2k Antenna
*04 SRT-4:AGP 50Trim Kit,S1,S2 Inj,S-AFC2,AEM Wideband,Turbo XS HPBC,PTP Direct Fit,PTP UHP-HKS SSQV,PTP 180 T-Stat,PTP CV,Maxxfab Magnaflow 3" TBE ,CoolingMist W/I 50/50 Mix M5 Nozzle,DCR Oil Mod,AEM SRI,MSD Wires,Bwoody MM's,Maddog 72%,Aeroforce Pro,255 Pump and Rewire,S-Tech's,HID's
Not installed: B&G Flash, Redstar Return Line, K-Sport CO's
Chino7385 is offline   Reply With Quote
Old 10-12-2007, 01:13 PM   #5 (permalink)
Mana4real's Avatar
Thank you guys. I looked all over an couldn't find anything on it. Where did you get that fuse holder? What brand is it? That's awesome!!
Old 10-12-2007, 02:17 PM   #6 (permalink)
Mana4real's Avatar
Found that connector... It's a Bussman part number BP/HHH. I just ordered two from my local supplier.
Old 10-12-2007, 02:21 PM   #7 (permalink)
BLKDOUTSRT4's Avatar
Member Number: 36285
dunno about everyone else but i intend on using the intercooler sprayer switch on my turbo toys bezel....i dont use intercooler sprayers so since the switch shows a pic of a lil spray i guess water meth sprays so itll be pretty cool imo !!!
Quote: Originally Posted by Alpha-Omega View Post
....yeah, I'm gay and staying home this time
BLKDOUTSRT4 is offline   Reply With Quote
Old 10-12-2007, 04:22 PM   #8 (permalink)
Member Number: 57999
i sense horrible things happening if im imagining it right.
press the switch to engage and spray the meth?
i pray you dont forget to press the switch again to shut it off. hydrolock is a bitch. and its already almost happened twice w/ my car and meth.
christian? is offline   Reply With Quote
Old 10-12-2007, 05:34 PM   #9 (permalink)
Mana4real's Avatar
Even with a boost pressure switch?
Old 10-12-2007, 08:02 PM   #10 (permalink)
the switch just provides power to the system it doesnt tell it to spray.....the boost pressure switch tells it when to spray....think....then read
Old 10-12-2007, 08:44 PM   #11 (permalink)
i did think. my thinking of your concept was obviously different fucknut.
w/o you going into detail, or ever playing w/ a toys watersprayer bezel, i can only conceptualize on how it works.
open your mind...then respond.
Old 10-12-2007, 08:59 PM   #12 (permalink)
i dont have to open my mind i was right and i dont know of any water meth system that you hold a button down to spray....sounds like a pita to shift and hold the button down
Page generated in 0.21931 seconds with 13 queries
