Old 11-05-2006, 05:42 PM   #1 (permalink)
Member Number: 17858
Default Where to get -50 Washer Fluid
Now, I'm not even sure if they sell it, although they have info on Engine Runup's site so I would imagine they do. I can get a steady supply of -20 and -25 at the local store but does anyone know if/where they sell -50? I live in Jersey which gets pretty damn cold, I would think that if they do sell it I should be able to get my hands on it.
Thanks.
Marc
Grifter is offline   Reply With Quote
Old 11-05-2006, 07:36 PM   #2 (permalink)
Member Number: 11814
Trader Rating: (109)
Thanks.
Marc
Just add some heet to the washer fluid, to bring up the methanol content to bring down the freezing point and then adjust your system to spray less or otherwise use it less often. I don't mean to imply turing it off, just dial the system back a little in the colder month's.
F/S, 03 fuel rail, 2 stock TB spacers, 2 10lb nitrous bottles, 1 15lb nitrous bottle, billet nitrous bottle brackets, lower heat shield, Mopar blue plate BOV w/surge valve, stock fuel rail bolts with extensions for fuel rail cover, 2 fuel rail covers, Digimoto ODBII scanner, NEW Mopar shift selector plate, nitrous 4an feed line 14', nitrous port injection hardware....and more
Old 11-05-2006, 08:03 PM   #3 (permalink)
SRToc Member
Member Number: 31840
Trader Rating: (24)
well...hopefully it never gets -50 where your at because I highly doubt washer fluid will work regardless....lol trust me I know from experiance.
Mods:stuff
1X.2X@12X MPH
david2345 is offline   Reply With Quote
Old 11-05-2006, 08:05 PM   #4 (permalink)
WOW alaska, damn you guys should not need WI other then maybe for two weeks a year.
Old 11-05-2006, 09:05 PM   #5 (permalink)
Thanks guys. I am aware of the Heet, just curious if they sold -50 anywhere around here. I'm probably just going to be using -20 or -25 and see how it is.
Old 11-06-2006, 09:45 PM   #6 (permalink)
NuthinS(RT4)pecial's Avatar
Member Number: 38363
Trader Rating: (17)
Advance Auto Parts or Discount Auto Parts sells -50 washer fluid.
NuthinS(RT4)pecial is offline   Reply With Quote
Old 11-06-2006, 10:38 PM   #7 (permalink)
Ok, thanks.
Old 11-13-2006, 07:17 PM   #8 (permalink)
SRToc Member
bigfaceFMIC's Avatar
Member Number: 24163
i got -30 from advance...hell i didnt even know there was -50
My next trap will be 122+mph or bust!
bigfaceFMIC is offline   Reply With Quote
Old 11-13-2006, 08:29 PM   #9 (permalink)
Blewbyu's Avatar
Member Number: 17234
probably doesnt get that cold where you live....
1997 GSX 12.21 @ 114 at 22 psi.... 1.59 60ft
2004 SRT-4 s2 12.89@109 SOLD 280whp and 330tq UNTUNED
PM ME IF YOU HAVE SAFCII or NEO PROBLEMS!!
NEO SETUP HELP 12.87 @ 109.2 on street tires (11.0 A/F)
Blewbyu is offline   Reply With Quote
Old 11-13-2006, 11:03 PM   #10 (permalink)
smokin-ricers's Avatar
Member Number: 10183
Trader Rating: (10)
I would be kinda leary of buying the -50 and using it B/C it may have glycol (or how ever you spell the stuff) in it to lower the freezing point beyond the normal freezing point of -20 stuff
I am STOCK
Ya know what I mean
DevilsOwnOnline
smokin-ricers is offline   Reply With Quote
Old 11-14-2006, 06:08 AM   #11 (permalink)
I was thinking the same, I would def. check it if I found it.
Old 11-14-2006, 07:05 AM   #12 (permalink)
If you need to lower the freezing point use the heat.
Old 11-14-2006, 09:44 AM   #13 (permalink)
chance@devilsown's Avatar
Member Number: 35658
Trader Rating: (30)
Grifter I would not mess with the washer fluid. Your best bet is to just find methanol supplier in your area. Call some race shops one should point you to a source to buy it. You should be able to find it for around 2.25 a gallon
chance@devilsown is offline   Reply With Quote
Old 11-14-2006, 04:09 PM   #14 (permalink)
Really? I am planning on using -25, I thought most WI guys used Washer Fluid? If you are that against I can also get Boost Juice.
Old 11-15-2006, 07:27 AM   #15 (permalink)
lilturbododge's Avatar
Member Number: 24594
its funny to see people think you are going to use it to clean your windows with, its because it is cheaper then buying meth, it is a higher amount of meth over water and the lower the temp the less detergent that is going to be in there.....
Good-bye pistons, Hello Rotary
lilturbododge is offline   Reply With Quote
Page generated in 0.23423 seconds with 13 queries
