Old 06-30-2007, 12:04 PM   #31 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (49)
Quote: Originally Posted by cali
This thread has been here since 2005 and now CM decides to drop in that try an ruin it....good job again WhizBang.....
Actually, no. This thread is a sticky. I have stayed out of this thread but when someone makes a statement with zero proof to back it up, I want clarification. Too many people will read this thread and get the wrong information.
Still waiting.
Old 06-30-2007, 04:46 PM   #32 (permalink)
cali's Avatar
Member Number: 159
Trader Rating: (15)
Still waiting.
You've gotta be kidding....I wait for slow to answer you....
I'll check back in a few days.
someone is watching me
Old 07-06-2007, 12:09 PM   #33 (permalink)
underSRTarmor's Avatar
Member Number: 32888
Trader Rating: (66)
so which is better
meth or den. alcohol???
Dodge Cummins 5.9L 325 hp 610 tq
Chevy duraless 6.6L 300 hp 520 tq
Ford PowerJoke 7.3L 300 hp 570 tq
underSRTarmor is offline   Reply With Quote
Old 07-06-2007, 12:17 PM   #34 (permalink)
OTownSRT4's Avatar
Member Number: 38911
Trader Rating: (13)
Quote: Originally Posted by underSRTarmor
so which is better
Better for what?
OTownSRT4 is offline   Reply With Quote
Old 07-06-2007, 01:59 PM   #35 (permalink)
Trader Rating: (66)
so which is better
Better for what?
over all
more hp gain less knock lower egt and intake temp
Old 07-06-2007, 03:13 PM   #36 (permalink)
J-SRT4's Avatar
Member Number: 37428
Trader Rating: (44)
^^^x2
17-50mm 2.8
50mm 1.8
55-200mm VR
3 SB600's
And some other thangs
55-200mm VR is for sale, mint condition!!
J-SRT4 is offline   Reply With Quote
Old 07-06-2007, 03:18 PM   #37 (permalink)
Trader Rating: (49)
Ok, I'll take a stab at it.
Denatured alcohol is easier to get but more expensive. Its believed to be in the 108 to 110 octain (maybe someone can confirm this).
Methanol is cheaper, harder to get. Believed to be closer to 118 octain (Again, maybe someone will confirm this).
both will have a good cooling effect but remember for EGT cooling you certaintly want some water. As you start adding higher concentrations of methanol your EGTs will rise VS higher concentrations of water. Atleast thats the data we have on alot of the big diesels we sell to, I would assume similar with a gasoline engine.
CM
Old 07-12-2007, 12:08 AM   #38 (permalink)
Member Number: 51090
Default PWM valve Vs. PWM pump speed injection
Whether its a PWM valve or pump system they accomplish the same thing, the main advantage of the valve system is that fact that its faster. Not all vehicles need the extra speed of the system..
CM.
same what thing?
they dont need the speed huh.....
are you selling alky systems or are you selling bull shit?
Just answer my question. Why will a PWM pump system cause over cooling and loss of power when using 100% water and not a PWM valve.
Answer that question in your best technical detail. You made the statement, answer it in a way that makes sense.
Cm
From a tuner that has tuned more Evos than anyone else
http://forums.evolutionm.net/showthread.php?t=282469
6 injectors, 3 fuel tanks and 2 fuel pumps
3" TBE, MBC@26psig peak
Aquamist methanol injection + DDS3 failsafe - http://forums.evolutionm.net/showthread.php?t=239686
JESTR tuned - gained 100TQ / 80HP - http://www.putfile.com/pic.php?img=4564538
SlowCar is offline   Reply With Quote
Old 07-12-2007, 06:13 AM   #39 (permalink)
Trader Rating: (49)
I was looking for a simple "yes" or "no". I will have to assume you agree with my position since you obviously avoided the question.
CM
Old 07-16-2007, 05:22 PM   #40 (permalink)
Member Number: 55722
Trader Rating: (-1)
is it normal when the meth kick's in to shoot out white smoke out of the exhaust and smell like oil is burning???
LAG KING is offline   Reply With Quote
Old 09-13-2007, 09:25 PM   #41 (permalink)
peteblksrt4's Avatar
Member Number: 43767
Trader Rating: (65)
i have a question with meth inj. would u be able to hold 20lbs to redline i have all supporting mods to spike 22lbs as of now but just curious if it will let me hold more to redline
STARTED SRT CAR CLUB IN AREA PM ME
Best Trap - 1.79 60 FT 12.3090 at 114.53
ported stock turbo
peteblksrt4 is offline   Reply With Quote
Old 09-13-2007, 11:00 PM   #42 (permalink)
SouthWest Moderator
jec1980's Avatar
Member Number: 34332
Question?
I have the S3R with Toys, havn't been able to find the specs on the Intercooler Pump.....but would the standard, Intercooler Spayer be effective as a Injection system? Its preset to come on and spray at set points and then also can be manually controlled.
Mopar All Day!
12.938 @ 111.28 MPH SIR Tucson (3000 ft. Elevation)
http://www.jmbat.com/swazsrt/
jec1980 is offline   Reply With Quote
Old 10-11-2007, 06:52 AM   #43 (permalink)
Member Number: 54230
Want to have fun with you engine?
Of the MANY sensors that monitor engine functions, one of them is a knock sensor. If the enging starts to knock it will retard (pull)the timming. So, do you know how to check to see if your knock sensor is working? Take a hammer and TAP (do not beat the sh-- out of the engine) on the engine block while the engine is running and you will see the computer pull timming out. The engine speed will change right in front of you.
gpbtt is offline   Reply With Quote
Old 06-10-2008, 10:58 AM   #44 (permalink)
Member Number: 24857
Can I ask a dumb nooB question...
If using a windshield washer fluid as the injected liquid, how would this affect fuel economy? the previous posts have stated that these injection techniques are good for fuel economy. I would like to know how? And does that fuel economy improvement apply to non-turboed cars as well? I would assume it should, since the fluid is being injected into the air intake path...
Maybe I am just stupid.
want2race is offline   Reply With Quote
Old 07-01-2008, 10:39 PM   #45 (permalink)
Member Number: 62791
Dude you're only injecting when the car is at full throttle so who cares about fuel economy? You would only see better fuel economy at WOT because the water injection allows you to run leaner mixtures without detonation because of the higher octane, leaner = less fuel.
Carentan'44 is offline   Reply With Quote
