Old 01-08-2005, 11:58 PM   #1 (permalink)
SRTforums Admin
Member Number: 1161
Default What is Water/Methanol/Alkyl Injection?
What is water injection?
Water injection is a technology that is nearly as old as the car itself. However, like many automotive technologies, it has waxed and waned as fashion has dictated. Water injection has the ability to suppress detonation, allowing the use of higher cylinder pressures. It is easy to control and relatively simple to install. In times of tight emission controls, decreasing fuel octane and rising petrol costs, water injection is one of the best ways of controlling detonation. And it has another major advantage over taking other approaches - the 'fuel' is available at almost zero cost!
How it Works
Water injection is used to suppress detonation. Detonation occurs when the flame front does not burn progressively across the combustion chamber but instead explodes into action. This causes a massive and sharp increase in combustion pressures which can damage pistons, rings and even heads. Detonation can sometimes be heard as a 'tink, tink' sound coming from the engine. The piston and head shown here has suffered severely from detonation.
Water injection works in three ways. Firstly, when the water is injected into the intake system prior to the cylinder head, the small droplets absorb heat from the intake air. Water has a very high specific heat rating (it can absorb lots of energy while only slowly increasing in temperature) and so the intake air is initially cooled. Next, the small drops of water start to evaporate. Water has a very high latent heat of evaporation (its change of state absorbs a lot of heat) and so the intake air charge is cooled still further. Finally, when the remaining water droplets and water vapour reach the combustion chamber, steam is produced. This acts as an anti-detonant and also keeps the interior of the engine very clean, so preventing the build-up of carbon "hot spots".
Water injection was first experimented with in the 1930s. At the time it was discovered that detonation could initially be prevented by enriching the air/fuel ratio. As cylinder pressures rose still further and that approach ceased being effective, the injection of water into the intake air stream was found to prevent detonation. Interestingly, the detonation remained suppressed, even if the air/fuel ratio was then leaned-out. This occurred because the excess fuel was being used to cool the combustion process. When water replaced fuel in performing this function, less fuel was then required.
This has major implications for both emissions and fuel economy at high engine loads. In fact Saab on some of their recent turbocharged cars has used water injection at high loads in conjunction with leaner air/fuel ratios to reduce emissions output and improve fuel consumption. To put this another way, at high engine loads it is possible to reduce the amount of fuel being used, replacing it with water without sustaining any loss of power!
--excerpt from autospeed.
So what is alky and methanol injection relate to water injection?
well they are the same , the diffrence is the type of liquids used on the resovoir.
Methanol has ability to act as a secondary fuel as well as a very fast cooling agent, problem is that 100% methanol is very expensive and its not feasable to run every day
Alky , is a type of alchohol used primarly to decrease the temperatures of the charged air , although cheaper than methanol , it will vaporize a lot faster than methanol or water thus not having the same level of efficiency in cleaning your motor and preventing detonation.
So what is the recommended mix for an SRT-4
Usually under regular summer weather's you want to use up to about 40% methanol with a mix of water. There are some pre-mixed solutions out there are around $1.00 a gallon, its called windshield wiper fluid ( check the bottle to make sure its methanol and not other types of alchohol as well as other chemicals that may harm your car)
Racing/Drag Racing : 100% methanol
Auto-X I would use straight distilled water with a diluted alkyl solution.
The above recommendations are based upon observation , if you have a better observation on what we should run please go ahead and post.
Thats why this forum was created. For communication for us old school peeps running these types of systems
http://www.hybridsrt.com
In remembrance of Andrew "HybridKid" Chin Shue
In remembrance of Steven "NightShade" Lorenz
FastAttack is offline   Reply With Quote
Old 09-07-2006, 10:19 PM   #2 (permalink)
silentwig's Avatar
Member Number: 30755
Trader Rating: (30)
good info
silentwig is offline   Reply With Quote
Old 10-06-2006, 12:08 AM   #3 (permalink)
turbotm's Avatar
Member Number: 46751
so do i just run a water nozzle to my air intake?
turbotm is offline   Reply With Quote
Old 10-06-2006, 12:11 AM   #4 (permalink)
SRToc Member
leepen's Avatar
Member Number: 21292
Trader Rating: (30)
god no...6"-8" from your TB in your uppipe
* Disclaimer...The above post may or may not have misspelled words ...deal with it
Scammed BY: daytonagts on 11/05 for $80+S&H
Scammed BY: Kustomatic on 4/06 for $250
leepen is offline   Reply With Quote
Old 10-06-2006, 12:27 AM   #5 (permalink)
turbotm's Avatar
when i got my carbon fiber hood it didn't have windshield fluid sprayers or holes for my stock ones and i ran the lines to the intercooler and put the hood nozzles on the ends for an intercooler sprayer. my q is can i tap a third line from there and run it to the tb position you're talking about and if so what should i use for the end of the hose to spray it or can i just run the water w/o a spray nozzle?
Old 10-10-2006, 04:47 PM   #6 (permalink)
Stracin's Avatar
Member Number: 25102
water injection pumps run at 100 to 150psi. Your windshield wiper pump isn't going to cut it if that's what you are getting at. You can use the windshield fluid reservoir for W/I though.
WHY DO THEY KEEP TAKING MY SIGS?!?!?!!?!
oliver the humanzee song
Stracin is offline   Reply With Quote
Old 01-30-2007, 03:28 PM   #7 (permalink)
DannyCobalt's Avatar
Member Number: 49327
Thumbs up
That is good info to know, i always wondered how and what the advantages were to these kits. good post
DannyCobalt is offline   Reply With Quote
Old 04-26-2007, 10:07 PM   #8 (permalink)
KONDA's Avatar
Member Number: 39092
Trader Rating: (20)
So question I can just use regular windshield wiper fluid from like wal-mart? Im having a hard time getting methanol, heet...
If I can use just regular windshield wiper fluid without messing anything up that would be great...
Oh and whats the different between methanol and windshield wiper fluid... more power with methanol?
WTB: Coilovers, LMK
KONDA is offline   Reply With Quote
Old 04-26-2007, 11:19 PM   #9 (permalink)
Turbocruiser13's Avatar
Member Number: 42620
Trader Rating: (18)
if you find somethin at walmart, shake the bottle and if it bubbles then don't use it. you want to use the stuff without soap in it for your injection. most speed shops/dyno shops/performance shops sell meth, or can get meth. wiper fluid doesn't do much for horsepower more for cooling and timing while meth does the same thing but adds extra octane into the mix
O4 PT Cruiser non GT
Stock b****es, come get me
Turbocruiser13 is offline   Reply With Quote
Old 04-27-2007, 04:35 PM   #10 (permalink)
KONDA's Avatar
Trader Rating: (20)
Nice thanks dude...
Old 05-07-2007, 11:55 AM   #11 (permalink)
SXTSpeed's Avatar
Member Number: 53059
Is water/alcohol injection legal for street use?
I don't see why water injection wouldn't be but no idea about alcohol injection
Current Car: 2004 Dodge Neon SXT
Plans
1) Pay it off
2) Sell it
3) BUY AN SRT-4
SXTSpeed is offline   Reply With Quote
Old 05-07-2007, 01:10 PM   #12 (permalink)
Trader Rating: (18)
There's no law saying you can't run 100 octane in your car is there? This is basically a means of upping your octane rating while keeping your afrs/knock/engine temps in check. It's been around for years now. Hell I think edelbrock was the company that designed them for the muscle cars in the 60s
Old 05-07-2007, 05:26 PM   #13 (permalink)
KONDA's Avatar
Trader Rating: (20)
Sorry to ask such a noob question but what is a knock...???
Or were you talkin' about if your valves are knockin, valve job?
Thanks!
Old 05-07-2007, 07:08 PM   #14 (permalink)
SXTSpeed's Avatar
No offense but that is a noob question Its cool though.
Knock is what happens in the engine when you use fuel that has a lower octane rating. It makes a knocking kind of noise in the engine and it can cause damage. Knock is usually seen when high performance engines use regular or medium grade gas
Old 05-10-2007, 08:29 PM   #15 (permalink)
KONDA's Avatar
Trader Rating: (20)
So then what happens if you always used a high rating gas and hear knocks...
Could the knocking be caused be something eles...
