Old 05-06-2008, 07:14 PM   #1 (permalink)
Member Number: 19079
Default What to check when Meth stops working
My coolingmist suddenly stopped working what are the signs of a bad pump?i have the old pump and not the new black one. Could it be anything else? thanks
CANIBUS115 is offline   Reply With Quote
Old 05-06-2008, 09:16 PM   #2 (permalink)
fr33fir3's Avatar
Member Number: 54378
How do ya know it stopped.. Take red wire connect it to the battery and black wire connect it to ground. If it pumps your still good if not.. well then ya know..
I would also not run it dry run some fluid though it.. Its how I tested mine when I first got it used.
www.Kingclamp.com
For All your map clamp needs.
Major Upgrades:
AGP Motor Mounts, Agp WGA, Agp Hard pipe, Agp Shift Selector, Greddy BOV, LFS 60MM TB, PTP Charge pipe, PTP fuel pump rewire PTP, PTP Wga spring, Walbro 255 lph Fuel Pump. Stage 2 W/toys. Apexi Safc II, Devils Own Progressive W/I, Turbo XS HP MBC, Innovate LC-1 & Gauge,ACT Clutch & Flywheel.
fr33fir3 is offline   Reply With Quote
Old 05-06-2008, 09:24 PM   #3 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (18)
Try hooking it straight to the battery first. If the pump wont spray tap it with a hammer and try again. Tap it all over like a stuck starter.
HCCAFan is offline   Reply With Quote
Old 05-07-2008, 01:27 AM   #4 (permalink)
Member Number: 63534
Drastic_Said is offline   Reply With Quote
Old 05-07-2008, 01:42 AM   #5 (permalink)
Member Number: 32196
Trader Rating: (15)
Come on you kids are young GET OFF THE METH!!
A853 Crew (ONLY UNO)
Starting all over from stock
Mods Now04 Silver Wilwood slotted BBK slotted,slotted Rear,Windage tray+crank scraper,Dcr power shift2 clutch,Bwoody Motor mounts+trany,Stock air box mod+K&N drop in,F&F Ported ex.Manifold,3" o2 housing,My catch can+check valve,Safc Neo,Agp waste gate + ptp spring,Agp uhp,lower
^ Coming Maxed Stocker WORLD RECORD 08
Racerxvsspeedracer is online now   Reply With Quote
Old 05-18-2008, 02:17 PM   #6 (permalink)
Member Number: 59795
go to mcmaster.com and buy a pressure sensor its like 20 bucks and well worth it. hook it up right before the line goes to the intercooler tube. buy a small led and wire it from the pressure sensor to the light inside the car. that way when the pressure sensor sees a certain psi a the light will turn on and you will know its spraying. i also had a cooling mist pump go out on me(the silver pump) i tested it a bunch of times and it worked but every time i installed it it stopped working, so i just bought a new pump.
samsonslmpson is offline   Reply With Quote
Old 05-28-2008, 01:36 AM   #7 (permalink)
FraziersSRT's Avatar
Member Number: 37867
Trader Rating: (46)
Check your ground.
WTB : BORG WARNER S256 TURBO - PM ME CASH IN HAND!!!
FraziersSRT is offline   Reply With Quote
Old 05-30-2008, 05:23 PM   #8 (permalink)
aww sheet's Avatar
Member Number: 20431
Trader Rating: (15)
check and replace the fuse, if the new one blows the the pump needs to be replaced
"There's nothing funnier than, a neon owner bashing another neon."
Car Domain
Old 06-01-2008, 10:44 PM   #9 (permalink)
SlowSRT05's Avatar
Member Number: 32481
Trader Rating: (32)
You need to list better details on what its doing?
Is it pumping but no water running throught it?
Is it taking in power by hearing a click but its not moving?
Is it not taking power by not hearing the click?
-Randy
Getcha Popcorn Ready! -T.O.
SlowSRT05 is offline   Reply With Quote
Old 06-20-2008, 12:05 PM   #10 (permalink)
Trader Rating: (46)
Ever find out whats wrong with it?
Old 06-25-2008, 05:27 PM   #11 (permalink)
no i still havent found out... the fuse is good and the ground is good as well. i think i just need a new pump. well the fuse looks good. could a good looking fuse be bad????
Old 06-25-2008, 05:40 PM   #12 (permalink)
Jagok1's Avatar
Member Number: 14366
So it's NOT spraying meth?
AGP GT40 ~ 460HP/430TQ by DSMLights
WTT: GT40 for S3Delta 47lb
Jagok1 is offline   Reply With Quote
Old 06-28-2008, 01:17 PM   #13 (permalink)
no its not... i first noticed when my car started running lean i think ive checked everything. im like 75 percent positive its the pump. i will recheck everything 2mrw and get back to u guys. thanks for all the input
Old 06-28-2008, 04:40 PM   #14 (permalink)
Member Number: 25021
My boost switch just went bad. Instead of removing everything I just switched wires around to test the pump by itself and the switch by itself. I took the power wire run to the boost switch and ran it straight to the pump, pump worked, moved the wire from the top pole to the bottom pole on the boost switch and nothing, that means a bad switch for me.
-Matt- -Drastic-
05 SRT-4 Stage 3 47lb FP Green
Old 06-28-2008, 04:52 PM   #15 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
Did you EVER connect the power wire to the battery????
That is the BEST way to see if the pump is broken.
FS: HID Fogs Kit - 6000K & 3000K(Yellow) - PM Me
Performance Mods: AGP S3D 48lb - Returnline - Mopar Stage 2 w/o Toys - DW 650cc - TurboXS HPMBC - Maddog STS - MaxxFab 3" DP w/o Cat Magnaflow Muffler - AIS Intercooler - ED LPP - ED UPP w/ HKS BOV - Injen Intake - NGK V-Powers @ .032 - FBM Ported Intake Mani/Spacer - DCR 55mm Throttle Body - DCR Oil Mod - Devils Own MethInjection, M5 - DTEC - AEM UEGO
385HP and 385TQ
Gmanigio is offline   Reply With Quote
Page generated in 0.18949 seconds with 11 queries
