Old 07-12-2008, 06:07 PM   #1 (permalink)
Tony35's Avatar
Member Number: 61633
Trader Rating: (15)
Default What AFR's do u run with W/I??
I just wanted to get an insite on what everyones AFRs were. Im running between 11.3 when boost is around 16psi and like 11.7-12.0 when its at like 20psi. I dont have a knock detector so i know some of u do and will know when it starts to knock if it even does with W/I. I know people say its bad to tune with meth because if the pump goes out or what not ull be running really lean and hurt the engine. The thing is i figure that u can see those lean AFRs and not boost untill the situation is resolved. Im not trying to debate what AFRs are good i just want to know what everyones is running. Thank You for any information on your tune.
Tony35 is online now   Reply With Quote
Old 07-12-2008, 06:12 PM   #2 (permalink)
lunchbox660's Avatar
Member Number: 10098
Trader Rating: (31)
i just leave the fuel tune pretty mcuh where it is and boost it a little higher. reason is because the stoich for methanol is actually not even remotely close to the same as for gasoline, so if you are running a larger nozzle and injecting alot of meth, a leaner tune is not necessarliy better. the meth will help suppress knock, but since it has a different stoich and you are mixing the two "fuels" i would just leave it alone. just my 2 cents. just boost it up a couple pounds and it will put a smile on your face
lunchbox660 is online now   Reply With Quote
Old 07-12-2008, 11:59 PM   #3 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
stoich doesnt matter, if you using a wideband its reading O2 content(Lambda) so its doesnt care what fuel you have. It reads the same!
Project log pics
Old 07-14-2008, 02:51 PM   #4 (permalink)
Tony35's Avatar
Trader Rating: (15)
It definatley makes a difference. like when im running it at 11.3 the wheels just break loose but when its at like 11.7 the wheels are barley gripping and u can feel the pull.
Page generated in 0.17042 seconds with 11 queries
