water meth or E85 - Page 3 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 02-04-2013, 08:49 PM   #31 (permalink)
SRTbacon's Avatar
Member Number: 89219
I currently run water/meth and I love it, however if e85 was available in Canada I wouldn't hesitate a second to switch. If you have it available take advantage of it!
SRTbacon is offline   Reply With Quote
Old 02-04-2013, 09:02 PM   #32 (permalink)
n00b-SRT's Avatar
Member Number: 90935
Default water meth or E85
What are you guys doing about your fuel level sensors? Just guestimating?
Sent from
n00b-SRT is offline   Reply With Quote
Old 02-04-2013, 09:27 PM   #33 (permalink)
SRT of the Month
underSRTarmor's Avatar
Member Number: 32888
Yep! = )
Old 02-04-2013, 09:48 PM   #34 (permalink)
kagekun's Avatar
Member Number: 57941
Perfect Example!
Today I was playing with my boostbox trying to get it dialed in, car wasnt running right, something was up.
I ran my tank nearly empty playing with settings and had an air bubble in the line from the truck to the engine, huge pain in the ass to remove.
Wish I had E85
Meth addict and CM is my dealer
Stone White ACR 315HP 407TQ
- 13.9 @ 108mph - 2.4 60' - Ugh Traction
All Your Methanol Mixing Needs
kagekun is offline   Reply With Quote
Old 02-06-2013, 02:07 PM   #35 (permalink)
Member Number: 91016
Default poooor
well the E85 has to wait now i just burned a hole in piston 1
Slow-srt4 is offline   Reply With Quote
Old 02-06-2013, 02:14 PM   #36 (permalink)
TropicanaNSRT's Avatar
Member Number: 92136
I ran e85 on my evo and it made a lot more power over running water/meth. Ill be tuning my srt on e85 as soon as it warms up. Reccomend it hands down.
2005 Orange Blast NSRT4
Walboro255, 1025 injectors, E85, DSP,
Needswings 3in catless downpipe with cutout, 3in exhaust, Injen CIA, AGP wastegate, HKS BOV w/ hardpipe, Godspeed BFMIC w/ hardpipes,ACT SS clutch,Tein lowering springs and Motegi ff7 wheels.
TropicanaNSRT is offline   Reply With Quote
Old 02-06-2013, 02:36 PM   #37 (permalink)
Default cool
well as soon as i get my car rebuilt ill be having it tuned to E85
Old 02-06-2013, 02:38 PM   #38 (permalink)
Default srt4
i was super pissed friday night when the pison burned up cus i just put 5k into this car and now i have to spend another 890 for piston and rods and have to redo all the work agian
Old 02-06-2013, 06:27 PM   #39 (permalink)
04COMPG's Avatar
Member Number: 7855
Quote: Originally Posted by lvlemphizstylez View Post
yeah actually having run it to see the difference i can say it doesn't make any when running e85. E85 cools plenty
please explain how this is possible. TALKING STRICTLY H20 AND E85
The injected fuel is ignigted and compressed within the cylinder. With the motor cycling at times over 91 rps, the thermal expansion and heating due to friction and the combustion within the chamber is controlled through e85 how exactly? I understand that the slower burn rate cools substantially, but at higher rpm's your injectors are working hard to supply enough fuel for the engine. Turbo efficiency could falter.
So in a high boost extended run, explain how the cooling of the intake temps via h20 is not helpful? How do you even measure cyl temps? The only drawback i can see is that the h2o may take up some of the much needed space the e85 will need for proper fueling.
Not being an azz, just want to know...
05 SRT4: DiabloSport, PTP Check Valve, DCR oil modifier, 160-tstat, K&N, Alky Injection, needswings 3" dump, Fm WGA and Stage 2
OH AND:
1993 Corolla DX 1.8L (373,000 miles daily driver)
1970 Buick Skyark GS (Just a buick 350)
2006 F150 (Eh, 4.6 V8, but has FlareSides)
04COMPG is offline   Reply With Quote
Old 02-06-2013, 06:37 PM   #40 (permalink)
04COMPG's Avatar
Member Number: 7855
One last thing, if e85 is roughly 105 octance and pure meth is 110 or so, couldnt you inject meth and get an octane rating above the est 105? You should be able to depending on nozzle size and flow...
Dangerous yes, but also i think possible
OH AND:
Old 02-06-2013, 07:16 PM   #41 (permalink)
SRT of the Month
^ wrong octane buddy.
E85 is roughly 96 Oct. meth 117.
Next with e85 u can run all the timing U need and can cross over mbt and be losing power by the time u knock.
Sent from
Old 02-06-2013, 09:05 PM   #42 (permalink)
Member Number: 51111
You think 100% of the fuel in your chamber is burned on every compression stroke? Even with pump fuel (all fueling) there is ample fuel in the chamber that cools and wets piston tops
E85 cools plenty as it burns (I'll say it again). And having run both (I'll say it again) in the real world I can tell you the water does nothing for performance (tried it on the dyno)
go ahead...change yours too now; again
lVlemphizStylez is online now   Reply With Quote
Old 02-07-2013, 01:25 AM   #43 (permalink)
Zenkat's Avatar
Member Number: 10522
Sent from
I just went to a salvage yard and nabbed 3 units from 3 00-04 neons i found. They should last awhile for sure. They were only $12 each, too. One is from a Chinese replacement canister one of them had. I'm curious how it holds up.
11.21@127.88
Zenkat is offline   Reply With Quote
Old 02-07-2013, 09:49 AM   #44 (permalink)
kagekun's Avatar
E85, being mostly Ethanol, has a much lower in chamber combustion temperature then that of gasoline. Simply put, it burns cooler.
E85 has a lower octane rating than methanol yes, but seriously, have you ever heard of someone complaining about knock with e85. It CAN happen, but legit knock with E85(a good batch) occurs far beyond what you could have even achieved with Water/Methanol injection to begin with.
More then a few people have backed this up with Dynosheet's and track run's.
Old 02-07-2013, 02:25 PM   #45 (permalink)
04COMPG's Avatar
Member Number: 7855
makes since to me...
of course ill test to confirm... one day...
thanks
OH AND:
