| Sponsored Links | |||
Advertisement | |||
#17 (permalink) |
![]() Join Date: Feb 2007
Member Number: 51111
seems you've never run an E85 setup on a Neon...begs the question of why you have any input in this thread. It's no different than having a tune that isn't spot on; the ecu compensates and unless you were logging the car you would NEVER know it
go ahead...change yours too now; again
![]() Last edited by lVlemphizStylez; 01-31-2013 at 05:42 AM. |
#19 (permalink) |
![]() Join Date: Nov 2007
Member Number: 59344
No, I haven't but I have run meth on a few cars, so please remove your panties from your butt crack
Meth with good failsafe - check gauge for errors. Fill tank when told by gauge. Check nozzles every 6 months E85 - Upgrade necessary fuel systems parts. Fill up at E85 pump. If you can't find one when you need gas, you have two choices. Fill up with 93 and 1. Not go WOT until your car adjust for 30% discrepancy, or two, keep your tuner in your car always. Worry about your fuel sender taking a dump. Just seems easier to run meth for me. Obviously you don't. Don't deny the OP the chance to hear both sides. |
#20 (permalink) |
SRT of the Month ![]() Join Date: Aug 2005
Member Number: 32888
I ran both on stock turbo
If u wanna compare dynos St motor sports dyno jet 274 whp 22 psi 70 % meth ran 8.5 at 85 mph. Tuned with map clamp back in 05 Cobb tuning mustang dyno 27 psi 299 whp e85 base rescale from duster 7.9 at 89.91(only ran 24 psi at track) Hmm. Sent from
#21 (permalink) |
Meth with good failsafe - check gauge for errors. Fill tank when told by gauge. Check nozzles every 6 months E85 - Upgrade necessary fuel systems parts. Fill up at E85 pump. If you can't find one when you need gas, you have two choices. Fill up with 93 and 1. Not go WOT until your car adjust for 30% discrepancy, or two, keep your tuner in your car always. Worry about your fuel sender taking a dump. Just seems easier to run meth for me. Obviously you don't. Don't deny the OP the chance to hear both sides. It takes 1 min to swap tune. U DON'T run 93 on e tune. Ur wot timing will be too high. (Notice I didn't say can't. I said u don't) Smh You swap to pump tune. Sent from
#22 (permalink) |
Yeah he's just against it because he choose one method. I have also run BOTH so I can actually talk about BOTH SIDES (imagine that; someone talking about both methods instead of someone with experience in ONLY ONE). More guys have lost motors due to methanol injection system failures than with E85 (fact); just do a search here and find quite a few. By the time you're done buying "fail safes" you could have made more power on E85 with less worry about "fail safes"
I'd rather worry about a fuel sender than a praying my meth system does what it's supposed to every time so I don't scatter my motor all over the road. A meth system is an ADDITIONAL fueling system to worry about that requires it's own special maintenance and tuning; point blank. BTW mine is still installed
![]() Last edited by lVlemphizStylez; 02-01-2013 at 03:23 AM. |
#23 (permalink) |
![]() Join Date: Sep 2007
Member Number: 57941
All of this is on point. I love my meth setup but would ditch it without thought if I had e85 within a 2 hour drive. Removing my front bumper to clean & test my injector every weekend, just to be sure, is a pain in the ass.
Meth addict and CM is my dealer
Stone White ACR 315HP 407TQ - 13.9 @ 108mph - 2.4 60' - Ugh Traction All Your Methanol Mixing Needs |
#24 (permalink) |
SRT of the Month ![]() Join Date: Aug 2007
Member Number: 56868
i would get a bosch 44
6an lines bottle neck fix fpr return line 1100 cc injector 03 or aftermarket rail.... BAM....
Cornfed and Tuned by Brian (Mindmelt101)
![]() Built by PJBwerkz ![]() R.I.P.- Eric aka nutz |
#25 (permalink) |
![]() Join Date: Feb 2004
Member Number: 7855
You can still use the w/I kit for cooling only. Just run distilled h2o; it'll keep your engine clean and Iat as well as any knock under control.
Nexus S 4G using AutoGuide.C
05 SRT4: DiabloSport, PTP Check Valve, DCR oil modifier, 160-tstat, K&N, Alky Injection, needswings 3" dump, Fm WGA and Stage 2
OH AND: 1993 Corolla DX 1.8L (373,000 miles daily driver) 1970 Buick Skyark GS (Just a buick 350) 2006 F150 (Eh, 4.6 V8, but has FlareSides) |
#27 (permalink) |
Member Number: 7855
it does nothing...I've run the water before makes no difference in power whatsoever
Are you saying with two equal cars fueled and tuned via dsp/e85 making consistant back to back runs on a hot low humidity summers day, with one with w/i and the other without, that they will run the same times back to back? I'm willing to put money on that one and i dont bet
#28 (permalink) |
there are to many things to take into consideration.....
intercooler is one... (how good of an ic) how much boost is another( are you out side turbo effency(sp) range?) turbo fans on the dyno..... but i can say this, back to back runs on water meth my hp when down .1 hp each pass 3 times in a row back to back on e85 my hp when down 2 hp each pass... both on stock turbos meth was 22 psi e85 was 27 psi
#29 (permalink) |
yeah actually having run it to see the difference I can say it doesn't make any when running E85. E85 cools plenty
#30 (permalink) |
I agree this is why I'm selling my w/I kit!!!! Sent from
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
