Old 05-09-2008, 12:34 AM   #1 (permalink)
bordeniuk's Avatar
Member Number: 46198
Trader Rating: (57)
Default using a m3 nozzle, 8KR
i have a DO progressive meth inj system w/ a 2bar controller.
i have a m3 nozzle. i did a WOT pull in third gear and my scan gauge read 6KR at about 4500 RPM and by redline it showed 8KR. my wideband read 11.5 at redline would a bigger nozzle help with my knock? the mix i run with is 50/50.
i was boosting 19lbs on a 60-1 trim
bordeniuk is offline   Reply With Quote
Old 05-09-2008, 05:11 AM   #2 (permalink)
RiVal's Avatar
Member Number: 51024
try 100% meth should deff take ur KR down
tune at 11.1-11.3 u might be able ta turn boost up withal rich AFR and 100percent meth
im not big turbo tho
hopefully big guys will post up
but deff try 100% guarantee that will help ya
-SMOKE-EM-UP- Eatin V8's spit on 6's and sh**in on any other
**New ET: 12.715 @ 110.686 2.038 60ft
91oct/ Street tires** :evilgrin
best Trap- 111.3
best 60ft- 1.972 street tires
**sO, s2 inj, AGP DFmic, AGP wga 23/15, APEXi safcII. NGK wideband, DUAL-AEROFORCE gauge's, NEEDSWINGS v6, MaxxFabb 02, CMist W/I, ported EX mani, TCS MOD, 60mm TB, and stuff
RiVal is offline   Reply With Quote
Old 05-09-2008, 05:15 AM   #3 (permalink)
RiVal's Avatar
^don't listen to that guy
yeah a bigger nozzle and maybe mess with different mixes. the M3 is way to small for ur setup. ull need like 4 M3 nozzles lol
ppossibly dual or directport might be best
the M3 is for like 300hp
ur pushing way more than that brah
Old 05-09-2008, 05:20 AM   #4 (permalink)
uncommon©'s Avatar
Member Number: 39843
Trader Rating: (127)
m9 is more suited for a 60-1
12.8 @ 122 street tires / pump gas
Old 05-09-2008, 10:41 AM   #5 (permalink)
bordeniuk's Avatar
Trader Rating: (57)
thanks for your help guys. im going to order one shortly.
Old 05-09-2008, 12:05 PM   #6 (permalink)
parsonsproject's Avatar
Member Number: 14704
Holy crap what was your KR before w/m? Are you sure the system is spraying and working correctly?
298whp/344wtq, before IM/TB/Spacer
Stage 1, Stage 2 WGA (18.4psi spike), SSA BFMIC, W/M injection, FnF Ported Turbo/Exhaust Manifold, 3" Maxxfabb O2 , 3" NW DP cutout open, AEM CAI, Maxfastest ported IM/TB/Spacer, Aeroforce interceptor pro, AEM Uego WB
<-- coSRToc 2007 dyno competition winner, stock turbo class -->
parsonsproject is offline   Reply With Quote
Old 05-09-2008, 12:17 PM   #7 (permalink)
bordeniuk's Avatar
Trader Rating: (57)
well ive had the system since stock turbo and on 18 lbs falling off to 15 with 91 oct. it was around 6KR, since then i have found a gas station with 93 oct i use that now but its probably the same shitty 91 cause, when i was in florida with the car this past month i had no knock on my 60-1.
im going to be getting some race gas soon so i can rule out it maybe being audible knock.
Old 05-09-2008, 03:54 PM   #8 (permalink)
Member Number: 63534
if u have that much KR, then you need to fix your tune BEFORE meth.
all youre doing is patching it up via meth, and if you meth takes a shit after youre tuned on it (itll be more aggressive), shit is gunna hit the fan..
Drastic_Said is offline   Reply With Quote
Old 05-10-2008, 08:10 AM   #9 (permalink)
smokin-ricers's Avatar
Member Number: 10183
Trader Rating: (10)
what drastic said ^^^^^^ it could be catastrophic failure if you don't
tune safely first without W/A then bring W/A into the mix and tweek everything till you get the most out of it
I am STOCK
Ya know what I mean
http://www.devilsownonline.com
smokin-ricers is offline   Reply With Quote
Old 05-10-2008, 08:50 AM   #10 (permalink)
Member Number: 8193
Something is not right with your engine managment. Or engine.
As others have stated it's a good place to start.
As for a larger nozzle. You are spraying into a 3 inch pipe. From what I have seen I would not go over a m5 in any piping under 3.5 inches. If you need more than a m5 can provide than add a second nozzle. Start with a m2 as the second. Keep them a min of 3 inches apart.
Also the bigger you make the hole (larger nozzle/ extra nozzle) the higher your on-set duty cycle is going to have to be.
Good Luck
Old 05-10-2008, 11:18 AM   #11 (permalink)
bordeniuk's Avatar
Trader Rating: (57)
Good Luck
the charge pipe i have is 2.5 inch. i know my tune is a little off, i figured. i had a pretty good afr at redline (11.5)
i mean the knocl comes in at about 4300 rpms, a little after the turbos spools up
Old 05-10-2008, 06:37 PM   #12 (permalink)
Member Number: 8193
2.5 sounds about right. My bad. I've been working on a DTE466 international and The plumbing for that monster is all that's in my head.
As for engine managment I was thinking timing, fuel. and air as a whole. Even something as simple as too hot a plug, or gap to wide.
Not saying I have a crystal ball that can see into your engine bay. Just an idea on where I would start.
Good Luck
Old 05-10-2008, 07:01 PM   #13 (permalink)
bordeniuk's Avatar
Trader Rating: (57)
Good Luck
i get where your coming from. next weekend im doing a boost leak test and changing the plugs and maybe have a buddy help street tune it.
Old 05-11-2008, 01:09 AM   #14 (permalink)
Chino7385's Avatar
Member Number: 30157
Trader Rating: (21)
What does your timing look like? You should definitely fix your tune before you run meth. Im not sure what your tuning with but even with a good amount of meth and nice a/f's you can still get KR from running too much timing. "Pulling fuel" with any kind of mapclamp could cause this.
Man, its been awhile since i posted in here. I use to live in this section.
*98 Neon R/T:Too Many mods
*00 Celica GT-S:I/E,STS,S-Tech's,S2k Antenna
*04 SRT-4:AGP 50Trim Kit,S1,S2 Inj,S-AFC2,AEM Wideband,Turbo XS HPBC,PTP Direct Fit,PTP UHP-HKS SSQV,PTP 180 T-Stat,PTP CV,Maxxfab Magnaflow 3" TBE ,CoolingMist W/I 100% Methanol,DCR Oil Mod,AEM SRI,MSD Wires,Bwoody MM's,Maddog 72%,Aeroforce Pro,255 Pump and Rewire,S-Tech's,HID's
Not installed: B&G Flash, Redstar Return Line, K-Sport CO's
Chino7385 is offline   Reply With Quote
Old 05-11-2008, 01:13 AM   #15 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (58)
hey man at 24 psi i get .5 kr with a 11.1-11.3 afr, useing a m7 with the pump turned up a hair
thats fantastic
AGP S256 + B&G FLASH
Page generated in 0.28067 seconds with 11 queries
