Quote: Originally Posted by
richrich
I found my MOPAR IC sprayer pump is cracked and actually came apart in my hand.
Would anyone have a good replacement suggestion or should I just buy stock s2/3? Preferably from advance, NAPA or Autozone.
If this is the wrong spot please move it mods....
Thanks
Rich
I've replaced mine with a Flojet FL122. You would need to cut and splice your wiring as its not going to use the plug on the toys harness. The inlet and outlet ports are not the same size but I do have some fittings that can be pressed into the ports of these pumps so as to work with the existing lines. The FL122 can be purchased online in many places (tpyically websites catering to marine and agriculture buyers)
Another nice things is that the FL122 does not need to be directly installed in the washer tank. So IMO its an easier install and less leak prone.
