Old 08-26-2009, 03:50 PM   #1 (permalink)
Member Number: 38189
Default stainless braided lines
anyone switched from quick connect fittings to stainless braided lines and fittings on their direct port systems?
rico's-srt is offline   Reply With Quote
Old 08-26-2009, 04:06 PM   #2 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
Sounds expensive
or 16 whatev
WTB: LCA bushings
Adionik is online now   Reply With Quote
Old 08-26-2009, 04:10 PM   #3 (permalink)
tell me about it, but i went and checked my meth connections today since my intake mani was off and all my connections were leaking
Old 08-26-2009, 04:11 PM   #4 (permalink)
quicky4JR.'s Avatar
Member Number: 43042
Trader Rating: (55)
^ Ha ha. JK rico. You always up to something! lol
Quote: Originally Posted by darrell cox View Post
Far better than stock but not as good as Nemos!
Leaders not followers! Paving the way and making it easy for everyone else!
(954)-915-0016
Davie,FL
Dyno tuning, installs, and custom builds
quicky4JR. is offline   Reply With Quote
Old 08-26-2009, 04:28 PM   #5 (permalink)
dude i was changing my bad power steering pump and decided to check the connections, and all the Y connections were leaking, so i might as well make it better lol
i got this now
nozzles
pump
Old 08-26-2009, 04:44 PM   #6 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (64)
Teflon hose with stainless braiding is the best hose you can get, period. Its difficult to work with, expensive but will last forever.
We dont do as much as we used do because of the high cost. Its not really the hose thats expensive its the fittings. With a direct port you need something like 15 or 16 fittings and they are very expensive.
your best bet is to go to your local hose store and get hose made for you. They can crimp a perminent fitting for you which is alot less expensive than the stainless steel removable compression fittings.
CM
Old 08-26-2009, 04:47 PM   #7 (permalink)
CM
any specific line you recomend?
Old 08-26-2009, 04:52 PM   #8 (permalink)
Trader Rating: (64)
Here is a source to view some hose.
Aeroquip Stainless Braided Hose, Hose Ends and Adapter Fittings
Not the most user friendly but the source.
Eaton Product Literature Library > Fluid Conveyance > Hydraulic Hose
Most cities will have an aeroquip shop where you can walk in and get hose cut for you.
McMaster car has hose pretty in-expensive. Its again the fittings you will pay out the ass for.
McMaster-Carr
-4 is the size you want.
CM
Old 08-26-2009, 04:57 PM   #9 (permalink)
thanks for all the links
Old 08-26-2009, 04:58 PM   #10 (permalink)
Trader Rating: (64)
Anthing to help out a fellow enthusiast!
CM
Old 08-26-2009, 11:54 PM   #11 (permalink)
Member Number: 42413
McMaster-Carr
CM
so it's just using small size braided fuel line hose then right?
Member 685
RVDSRT4 is offline   Reply With Quote
Page generated in 0.17616 seconds with 13 queries
