Old 03-26-2008, 09:02 PM   #1 (permalink)
Member Number: 58932
Default Relay testing.
Anyone now how to test a 12vdc 30/40A relay to see if it is good?
Old 03-26-2008, 09:05 PM   #2 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (51)
Take an LED and hook up to the 87 PIN, give 30 12V power, give 86 12V power and when you ground the 85 the led will light up. remove the ground from 85 the LED will turn off.
David
Old 03-26-2008, 09:08 PM   #3 (permalink)
David
What if I dont hve a LED.
Can I just give it power and see if it clicks.
Old 03-26-2008, 09:25 PM   #4 (permalink)
Trader Rating: (51)
the relay should click as well, I cant say that would be as accurate but it should work. our relays click as it closes the circuit.
David
Old 03-26-2008, 09:41 PM   #5 (permalink)
So give 30 and 86 power and ground 85 then it will click
Old 03-26-2008, 09:48 PM   #6 (permalink)
goats srt's Avatar
Member Number: 47689
u also should use a ohm meter cause just because it clicks doesnt mean its still good, poor or dirty contacts in the relay will cause it not to make connection
Old 03-27-2008, 07:47 PM   #7 (permalink)
moparmansrt4's Avatar
Member Number: 50684
I agree if you have an ohm meter, test across the coil first, (black and white) (You won't get a direct reading since there is resistance through the coil but as long as it doesn't read open then you are good to go.)Then test between the blue and yellow and manually close the contact if it rings through it is good.
Quote: Originally Posted by rollwitstyle View Post
the srt is the worst car to buy it sucks so much balls and tastes like doo doo. buy the t/a they are the fastest cars ever and they taste like steak....... by the way pm me atleast a week in advance if you plan to visit ny
http://www.srtforums.com/forums/f106...ml#post5894846
moparmansrt4 is offline   Reply With Quote
Old 03-30-2008, 01:22 PM   #8 (permalink)
got it working thanks to CM.
thanks guys.
Old 03-30-2008, 05:05 PM   #9 (permalink)
Trader Rating: (51)
Glad I can help.
David
Old 03-31-2008, 12:05 PM   #10 (permalink)
chance@devilsown's Avatar
Member Number: 35658
Trader Rating: (30)
Relays can click and still be bad.
Relays can easily be tested this way.
DevilsOwn Injection - Articles - Tech Articles - Troubleshoot relay
chance@devilsown is offline   Reply With Quote
Page generated in 0.17142 seconds with 11 queries
