Old 06-01-2008, 11:22 AM   #1 (permalink)
AmSlow06's Avatar
Member Number: 54684
Default Quick question on Meth GuyS????
1: How does our cars react 2 a meth kit???
2: Do i need a tune 4 it so it can work better w/ my car???
3: How many mods do i need 2 run meth safely???
AmSlow06 is offline   Reply With Quote
Old 06-01-2008, 08:16 PM   #2 (permalink)
smokin-ricers's Avatar
Member Number: 10183
Trader Rating: (10)
most of the time you will get some nice results un-tuned as long as you don't inject too much fluid to soon and bog the car down
to get the optimal results yes you do
but tuning to where you are dependent on meth to run safe or not is still a very debated topic myself personally I am not dependent on meth to run safely
none at all a but wideband A/F gauge is a must just to see where your AFR is you don't really wanna exceed 11.5-11.9 AFR or pop goes the engine if your not lucky
but if you really wanna see meth shine you will need some way to pull enough to be dependent on meth to run safely
I am STOCK
Ya know what I mean
DevilsOwnOnline
smokin-ricers is offline   Reply With Quote
Old 06-02-2008, 08:29 PM   #3 (permalink)
AmSlow06's Avatar
Thanks ,an u really gave me an idea and helped alot but am still gonna have 2 do alot of reading and research on the mod b4 i do it cause i dont want my motor 2 go pop!!!!
Old 06-03-2008, 08:02 AM   #4 (permalink)
Member Number: 8546
there are 2 kits id only mess with and thats the devils own and coolingmist. I have the coolingmist trunkmount it works wonders . Im playing with it still little by little.
Alot of haters out there with no job,no money or a life or got their cars repo-ed you know who you are. Get a grip racist womp homo's stop concentrating on me im gettin my paper If you got hatred in your blood you must be a broke jealous bitch,suck hairy balls you homo's
srt-sparkle is offline   Reply With Quote
Old 06-04-2008, 08:51 PM   #5 (permalink)
moparmansrt4's Avatar
Member Number: 50684
I also have the coolingmist and I love it. The only thing I wish i would have done different is I wish i would have gotten a progressive controller of some sort. Meth injection with a fuel controller is a great way to increase timing, while upping boost, and leaning out your afrs to make significantly more power and staying safe on pump gas. Good luck on your decision and if you have any more questions just post up buddy.
Quote: Originally Posted by rollwitstyle View Post
the srt is the worst car to buy it sucks so much balls and tastes like doo doo. buy the t/a they are the fastest cars ever and they taste like steak....... by the way pm me atleast a week in advance if you plan to visit ny
http://www.srtforums.com/forums/f106...ml#post5894846
moparmansrt4 is offline   Reply With Quote
Old 06-05-2008, 06:38 AM   #6 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (51)
Always remember when your budget allows you can add our Vari-cool to your kit
David
Old 06-05-2008, 08:18 AM   #7 (permalink)
Member Number: 8546
Default AmSlow06
well it basically boosts your octane safely and more efficiently without the need to use racegas all the time. It keeps the engine cooler by steamcleaning and absorbing the heat bringin the temps down.
Well you dont actually need a tune if you have a stage kit and plan on runnin hom all day. But a tune is most effective though to gettin more power out of it . Bolting it on alone with give you about 20extra whp.
Well you dont need alot of mods to run it safely just a bigger intercooler if you choose to make it as cold as possible and a nice 3inch tbe.
Old 06-16-2008, 02:35 PM   #8 (permalink)
jpleasureking's Avatar
Member Number: 33798
I am running devilsown progressive controler with m5 nozzle 150psi pump 60/40 watermeth. Stock tubro runinng agp wastegate and all other mods for big turbo. Wideband a/f hit 12.6 at its highest in 4th gear at 23 boost and dropping to 12.3 at red. I rarely see 1 count of knock unless i hit bumps. 3rd is in the 12 a/f with no knock so i would say water/meth is helping, EGT are all under 1625 at there highest as well.
jpleasureking is offline   Reply With Quote
Old 06-29-2008, 11:07 AM   #9 (permalink)
AmSlow06's Avatar
Thanxs guy Yall been really helpful! Know which is a better kit! Coolingmist or devils own?
Old 06-29-2008, 11:16 AM   #10 (permalink)
mole''s Avatar
Member Number: 17477
Trader Rating: (173)
Coolingmist FTW!!!!!!
PTperformance PTP's Cali CREW Mole'
co-founder of www.casrtoc.com
100% BONE STOCK.
Old 07-01-2008, 11:18 PM   #11 (permalink)
Member Number: 52407
David
Is there a difference between the vari-cool kit and say a standard kit?
7055 is offline   Reply With Quote
Old 07-02-2008, 05:37 AM   #12 (permalink)
Trader Rating: (51)
Yes, the Vari-Cool kit has our Vari-Cool controller, the standard kit injects "on/off" based on boost, not progressive.
If your budget says "yes", the Vari-Cool is the way to go. If not, get the standard kit and upgrade later.
CM
Old 07-08-2008, 09:13 PM   #13 (permalink)
AmSlow06's Avatar
Awsome, i'll post up a link of d one I want and u guys tell me if its any good =)!!!! Tell me wut yall think???
Coolingmist Water Injection, alcohol injection and Methanol Injection systems
Page generated in 0.19044 seconds with 11 queries
