Old 05-28-2008, 01:33 AM   #1 (permalink)
FraziersSRT's Avatar
Member Number: 37867
Trader Rating: (46)
Default Which nozzles with my setup?
Hey guys im trying to get some opinion's on which nozzles I should be using with my setup.My motor has the following modifications...
-49lb S3 Externally Gated
-750's
-3" TBE
-3" SRI
-DCR 255
-DCR Oil Mod
-Exhaust Depot Super Beast FMIC
-Hard pipes
-Return line
-AEM EMS (not yet installed).
-Devils Own 3 bar progressive trunk mount kit (not yet installed).
-All stock internals
And pretty much all of the rest of the supporting mods to push 400WHP safely on pump gas.Im aiming for 400WHP on pump gas at least and my question was...do you guys think two M5 nozzles will be fine for me or do you think I should run one M5 and one M7?Also...which one would I put before which or would it really matter?Any help will be greatly appreciated. Thanks!
-Frazier
WTB : BORG WARNER S256 TURBO - PM ME CASH IN HAND!!!
FraziersSRT is online now   Reply With Quote
Old 05-28-2008, 11:04 AM   #2 (permalink)
Trader Rating: (46)
Come on SOMEBODY has to know 11 people already viewed this thread!!
Old 05-28-2008, 05:01 PM   #3 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (18)
I think one M5 is fine, maybe a M7. 2 M5s....no. You don't have toys right?
HCCAFan is offline   Reply With Quote
Old 05-28-2008, 11:21 PM   #4 (permalink)
Trader Rating: (46)
No toys,just looking to get rid of knock here and some POWA!
Old 05-30-2008, 04:58 PM   #5 (permalink)
SRT-4_UK's Avatar
Member Number: 32106
Trader Rating: (19)
at least m5 or bigger.
SRT-4_UK is offline   Reply With Quote
Old 05-30-2008, 08:50 PM   #6 (permalink)
Trader Rating: (46)
SRT-4 UK - Two nozzles or just one? How about just one M7?
Old 05-30-2008, 11:06 PM   #7 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
Ive got one M5 right now with all the mods in my sig.
Seems to do the job but I too was thinking about adding another M5 nozzle.
FS: HID Fogs Kit - 6000K & 3000K(Yellow) - PM Me
Performance Mods: AGP S3D 48lb - Returnline - Mopar Stage 2 w/o Toys - DW 650cc - TurboXS HPMBC - Maddog STS - MaxxFab 3" DP w/o Cat Magnaflow Muffler - AIS Intercooler - ED LPP - ED UPP w/ HKS BOV - Injen Intake - NGK V-Powers @ .032 - FBM Ported Intake Mani/Spacer - DCR 55mm Throttle Body - DCR Oil Mod - Devils Own MethInjection, M5 - DTEC - AEM UEGO
385HP and 385TQ
Gmanigio is offline   Reply With Quote
Old 06-01-2008, 01:24 AM   #8 (permalink)
Trader Rating: (46)
Hmm... why not just upgrade the one nozzle instead of running 2? Or should I have just gone with an M10 or M12?
Old 06-01-2008, 11:27 AM   #9 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
Well, I have my nozzle after the sensor, so I was thinking of putting another m5 before the sensor so it sees the cooler temps, maybe helping with HP.
Old 06-01-2008, 11:52 AM   #10 (permalink)
Pimpazzberetta's Avatar
Member Number: 29361
Trader Rating: (39)
I would try a single nozzle first. Less hassle and less holes to mess around with. Start with an M7 first. I use an M5 and is not enough.
Mopar Stage 3R w Toys 388.8 WHP 425.5 WTQ
Mopar CAI,Mopar BOV,S3 C/O's,AGP S3 WGA
SBC 5X,TC BFMIC / t bolt clamps, 55 mm TB, Maxxfab 3" o2,3" catless DP,Injen 3" catback, FBM intake mani
NGK 4306 @ .033, Devils Own W/I w controller
UEGO, Greddy TT, Ultra Lite II 30/30,Scan Gauge
DC Sports STB, MM inserts, Boomba trans mount
LCA, strut tension, Booger bushings,CV,18" Konig's,TCS, D/S Rotors
Pimpazzberetta is offline   Reply With Quote
Old 06-01-2008, 10:39 PM   #11 (permalink)
SlowSRT05's Avatar
Member Number: 32481
Trader Rating: (32)
Try an M10 first, If you ave a controller than you can control the flow on it. Im running an m10 right now and im back at stock boost levels on PCM control on my stage 1 til my clutch goes in and i have zero issues with that size of a nozzle.
An m5 wasnt enough for me and neithe was an m7 and you have WAAAAAYYYYY more mods than i do.
Also im running straight water on stock boost levels with an m10.
-Randy
Getcha Popcorn Ready! -T.O.
SlowSRT05 is offline   Reply With Quote
Old 06-01-2008, 10:58 PM   #12 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
Im running 100% meth if that matters... 1 m5 nozzle with the mods in sig,
I want to either add a nozzle before the sensor or go M10,
NOT SURE!!!!!!!!!!!!!!!
Old 06-02-2008, 01:07 AM   #13 (permalink)
Chino7385's Avatar
Member Number: 30157
Trader Rating: (21)
Its better the run two smaller nozzles then to run one big one. Smallers nozzles atomize better. Since you already have an m5 on that pipe, you can run a second nozzle before the intercooler inlet for added cooling. I plan on running a m2 or m3 somewhere on the turbo charge pipe.
*98 Neon R/T:Too Many mods
*00 Celica GT-S:I/E,STS,S-Tech's,S2k Antenna
*04 SRT-4:AGP 50Trim Kit,S1,S2 Inj,S-AFC2,AEM Wideband,Turbo XS HPBC,PTP Direct Fit,PTP UHP-HKS SSQV,PTP 180 T-Stat,PTP CV,Maxxfab Magnaflow 3" TBE ,CoolingMist W/I 50/50 Mix M5 Nozzle,DCR Oil Mod,AEM SRI,MSD Wires,Bwoody MM's,Maddog 72%,Aeroforce Pro,255 Pump and Rewire,S-Tech's,HID's
Not installed: B&G Flash, Redstar Return Line, K-Sport CO's
Chino7385 is offline   Reply With Quote
Old 06-02-2008, 01:15 AM   #14 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (60)
m5 and m3 with the pump turned up a little on a 50trim at 24psi 1-1.5 kr pump
thats fantastic
AGP S256 + B&G FLASH
Old 06-02-2008, 01:26 AM   #15 (permalink)
Trader Rating: (46)
Hmm..well thanks for all the info guys! Ill probably just run the 2 M5's then.That sounds like my best bet.Anybody have pictures of there dual nozzle setup and how they did things?
Page generated in 0.19571 seconds with 11 queries
Search Engine Optimization by
