Old 09-12-2009, 03:09 PM   #1 (permalink)
GdnSrt4Stg3's Avatar
Member Number: 31013
Trader Rating: (21)
Default Noozles size?
What size of nozzles do i need? currently running direct 4 port M2 nozzles..... i have a agp 3147 agp fuel, stg2 injectors, agp sct tune boosting 23psi.... seems like i still gets 5kr knock on 5000rpm and up!!!!!!!! timming at 23degree 26degree, even when i turn down the boost to 18psi, still get 3-4kr knock.........is it i have to get bigger nozzles?
anyone?
GdnSrt4Stg3 is offline   Reply With Quote
Old 09-12-2009, 03:28 PM   #2 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
Have you taken off your intake manifold to see if the nozzles are spraying properly? I'm willing to bet that's your problem. Because that is waaaaaay enough meth for that turbo.
Buddy of mine had a direct port setup and was getting a shitload of KR. So we took off the nozzles and they were like a 60 year old pissing with an inflamed prostate
or 16 whatev
Adionik is online now   Reply With Quote
Old 09-12-2009, 03:50 PM   #3 (permalink)
Turbolag87's Avatar
Member Number: 6491
F&F Stage III 47lb turbo
Returnline
AGP WGA,
Rolling thunder Race head
11.40@125mph 26psi and no boost leak
New times with new race head coming soon
Turbolag87 is offline   Reply With Quote
Old 09-12-2009, 06:08 PM   #4 (permalink)
Trader Rating: (21)
yes the meth are spying good... tested with air compressor. its a brand new kit from coolingmist.
maybe settings are off? left dial start spying at 10s. and right dial at 15?
think maybe i should put race gas and see if its still knock
Old 09-12-2009, 06:10 PM   #5 (permalink)
Trader Rating: (21)
Quote: Originally Posted by Turbolag87 View Post
hummm M2 way too much???? should i get some M1 then? fuk should of listen to coolingmist.
Old 09-12-2009, 06:16 PM   #6 (permalink)
Adionik's Avatar
Trader Rating: (25)
No, M1's are too small IMO. You want that headroom. What do you mean tested with an air compressor? Put water in your tank and activate your meth to see the spray pattern...what are you talking about?
Page generated in 0.14478 seconds with 13 queries
