Old 07-11-2008, 10:41 PM   #1 (permalink)
1QKSrt4's Avatar
Member Number: 56257
Default New to water/meth help!
So a buddy of mine who isnt on the forums just picked up a brand new snow performance kit, this one to be exact
Snow Performance: Stage 2 SRT-4 Boost Cooler?
Just curious so i dont know much about meth and neither does he, what else does he need? I was thinking all he needs is the solenoid upgrade if he mounts the tank in the rear or in any place where its higher than the nozzle, correct? Anything else im missing?
HATED............
1QKSrt4 is offline   Reply With Quote
Old 07-11-2008, 11:14 PM   #2 (permalink)
OTownSRT4's Avatar
Member Number: 38911
Trader Rating: (13)
nothing
OTownSRT4 is offline   Reply With Quote
Old 07-12-2008, 12:17 AM   #3 (permalink)
fr33fir3's Avatar
Member Number: 54378
yea just needs a check valve and he is set.
www.Kingclamp.com
For All your map clamp needs.
Major Upgrades:
AGP Motor Mounts, Agp WGA, Agp Hard pipe, Agp Shift Selector, Greddy BOV, LFS 60MM TB, PTP Charge pipe, PTP fuel pump rewire PTP, PTP Wga spring, Walbro 255 lph Fuel Pump. Stage 2 W/toys. Apexi Safc II, Devils Own Progressive W/I, Turbo XS HP MBC, Innovate LC-1 & Gauge,ACT Clutch & Flywheel.
fr33fir3 is offline   Reply With Quote
Old 07-12-2008, 07:51 AM   #4 (permalink)
OTownSRT4's Avatar
Trader Rating: (13)
I think there was a CV in that pic
Old 07-12-2008, 07:44 PM   #5 (permalink)
1QKSrt4's Avatar
What is the check valve?? What does it do?
Old 07-12-2008, 08:00 PM   #6 (permalink)
srt4geezer's Avatar
Member Number: 910
Trader Rating: (12)
Keeps the meth from continuing to dribble into the Intake piping when not under boost. Especially good for when parked. If no check valve fluid will continue to drip into intake/IC & flood the motor when you start your car.
11.9@117 so far
Work harder, millions of people on welfare are depending on you.
srt4geezer is offline   Reply With Quote
Old 07-12-2008, 08:10 PM   #7 (permalink)
1QKSrt4's Avatar
Wouldnt that be the same thing as having the solenoid i talked about??
Old 07-12-2008, 08:23 PM   #8 (permalink)
srt4geezer's Avatar
Member Number: 910
Trader Rating: (12)
Solinoid does the same thing. Just more complicated. Checkvalve = simple.
Old 07-12-2008, 08:28 PM   #9 (permalink)
1QKSrt4's Avatar
Alright sweet, my buddy can pick up the solenoid cheap so i think hes gunna go that way. Thanks geezer!
Old 07-27-2008, 08:58 PM   #10 (permalink)
woltegsrt4's Avatar
Member Number: 10193
Trader Rating: (36)
If the bulkhead fitting on the tank is lower than where you have your nozzle then you don't need a check valve/solenoid. This kit DOES NOT include a check valve. This is supposed to be built into the pump. Adding an extra checkvalve with hurt the fluid pressures. I'm using this same kit with a M5 cooling mist nozzle. Works good!
woltegsrt4 is online now   Reply With Quote
Old 07-28-2008, 06:28 PM   #11 (permalink)
1QKSrt4's Avatar
So if you used the window washer tank you would be solid then.
Old 07-28-2008, 07:09 PM   #12 (permalink)
woltegsrt4's Avatar
Trader Rating: (36)
yup, if you are only using one nozzle at the UPP higher than the bulkhead fitting!
Page generated in 0.27387 seconds with 11 queries
