Old 11-04-2009, 10:50 PM   #46 (permalink)
Member Number: 52407
Quote: Originally Posted by ptperformance View Post
Ding, winner. It works but the car doesn't like to be taken off IAT cooling then have it turned back on when your sitting on the dyno.
I don't understand that, if that was the case then wouldn't people running direct port have the same problem?
7055 is offline   Reply With Quote
Old 11-04-2009, 11:10 PM   #47 (permalink)
BigBird03's Avatar
Member Number: 60153
Trader Rating: (42)
+1, I was wondering the same?
BigBird03 is offline   Reply With Quote
Old 11-05-2009, 12:44 AM   #48 (permalink)
Member Number: 9051
Trader Rating: (17)
I think what he was saying is that they were having trouble with their tester car.... that they would do a run with the WI running in a dual nozzle setup.... and then run it without the nozzle underneath the IAT... it throws the tuning out of whack
pphilps is online now   Reply With Quote
Old 11-05-2009, 05:31 PM   #49 (permalink)
turbojack's Avatar
Member Number: 11814
Trader Rating: (122)
I'm sure the tuning difficulty is more of an issue in the control of the injectant more then the location that the injectant is being introduced.........I have spoken to pro-tuners and its not easy to get a car dialed in for best performance results with a large amount of injectant that is not linear to the primary fuel delivery. Its a bigger problem the more basic the control is and the more controls needing to be tweaked............tuners do not like going back and forth between control mechanisms.
As stated previously the issue with the location in question is wet flow in a part designed for dry flow. Once the injection point is desired to be nearer to the cylinders, port injection is needed.
Page generated in 0.10954 seconds with 14 queries
