Need help immediately
I have been working on my car all day installing my W/I kit. I have run into quite a pickle.
I was not given anything to tap into my windshield wiper fluid tank, and my original idea didnt work so well. I drilled a 5/16 hole, and put a metal 3/8 size vacuum line (style) connector and tried gorrilla glueing it to the tank and then connecting my hose.... did not work.... so now i have a hole and i need some ideas quick
also, my kit is an enginerunup kit. For my injector, i drilled the correct size hole into my stock cold side pipe, and put the injector inside, with a washer on the outside and tightened it into the 90 degree elbow style connector that has the line run to the checkvalve. Im pretty sure it is boost leaking from there a little bit.... what can i do to get rid of the leak? JB weild smeared on the rubber pipe and over the washer? help!
2005 SRT-4 - Totalled 01/05/08
2003 SRT-4 - 12.691 @ 114.87 on low boost/pump gas, stock turbo and street tires!!!
