Old 04-21-2006, 11:21 AM   #1 (permalink)
benmcc2003's Avatar
Member Number: 27591
Default more proof w/i works
after pulling the head off my srt4, the pistons looked brand new still. after 11,000 miles of california 91 oct piss. W/I was one of the first mods and could not be more happy with how clean, lack of carbon build up there was. the should could not beleive how nice 3 of them looked. the last was a small ball of metal sitting in my oil pan. but that was from bad casting or weak rod. granted the blown motor sucked but could not be more happy with the w/i, not only for its abality to defend knock but keep the motor clean. made a true beleive out of me.
Built motor, AEM EMS, DBB 50. gets the job done.
benmcc2003 is offline   Reply With Quote
Old 04-21-2006, 12:14 PM   #2 (permalink)
manic_mopar's Avatar
Member Number: 25488
Trader Rating: (32)
and no pictures?? Whats wrong with you?! lol, that makes me feel good about my w/i purchase. Just hope i'll never have to pull my head.
Pablo Tuned: 402WHP/444WTQ I'm a meth addict...
Stage 3R powered
manic_mopar is offline   Reply With Quote
Old 04-21-2006, 01:28 PM   #3 (permalink)
Eagle Pilot's Avatar
Member Number: 21335
He he, You said 'pull my head'!
Eagle Pilot is offline   Reply With Quote
Old 04-21-2006, 04:40 PM   #4 (permalink)
goldfingerfif's Avatar
Member Number: 30907
Proof that it works?? Who said it didn't?
If someone doesn't think it works then they are a moron and do not understand the concepts of a gasoline engine.
goldfingerfif is offline   Reply With Quote
Old 04-21-2006, 08:35 PM   #5 (permalink)
benmcc2003's Avatar
Default thought
yeah, just thought i would throw up some proof. there are many people who question W/I. I never did, i researched the hell out of it first. the idea has been around a long time, WWII era.
Old 04-21-2006, 10:06 PM   #6 (permalink)
Yep, I am a STRONG believer in w/i, I love it to death. WAAYYY better than richening the car.
Old 04-21-2006, 10:23 PM   #7 (permalink)
Trader Rating: (32)
man, and when i said that i knew someone was gonna comment on it. lol
Old 04-23-2006, 08:19 AM   #8 (permalink)
mario03srt's Avatar
Member Number: 1602
Trader Rating: (21)
Lack of Carbon reduces the detonation!!!
W/Inl is ALL good.
Marion
mario03srt is offline   Reply With Quote
Old 04-23-2006, 08:53 AM   #9 (permalink)
Member Number: 10600
Trader Rating: (66)
i have some datalogged #s for people, with my turbo at 21psi, water injection on, i logged the knock rate on my tech gauge and doing a 4th gear pull, my knock rate was below 1 the whole way from like 50mph up to 120mph. then i did another one where the water injection was off (have it hooked up to a switch), and the knock rate was at 5-7 the whole way.....just some info to think about
+1 for water injection
Jeff@Slowboy is offline   Reply With Quote
Old 04-23-2006, 01:58 PM   #10 (permalink)
turbojack's Avatar
Member Number: 11814
Trader Rating: (123)
I predict that water injection will at one point be a factory option or be a part of an turbo upgrade package like Mopar stage II/III. Can you imagine the possible effect of WI if the PCM was controlling it instead of an aftermarket setup? Some high end specailty cars are at this point or are close to this.
When I say an option I mean a necessary component to achive optimal performance from an engine.
When the factory last had production vehicle with WI, advanced electronics and computers were not even close to being used. With advanced electronics and smarter engine control systems and the fact that WI is being more understood and sometimes necessary performance enhancement, we are not that far from it happing. No longer will a noob owner/driver screw things if the water tank/supply goes empty or a WI component fails, hence keep the factory from using proven methods and technology to insure best performance.
Old 04-28-2006, 12:26 AM   #11 (permalink)
19 psi's Avatar
Member Number: 12457
Trader Rating: (39)
I had my W/I turned off for about 100 miles and on WOT pulls I started to notice a burning smell coming from my car that I though was the clutch going out, but turned out that it was somthing else that was burning up somewhere cuz smell went away after I turned on the W/I again. Oh ya im boosting 24 psi to
mzods:
S3r tial wheel AGP S3 WGA 30psi
bosch 1000cc inj. E85 (HOM everywhere)
KW V2 coilovers
Boomba mounts
CM S3
E46 bi-projector full retro'd headlights
+ every other bolt on
19 psi is offline   Reply With Quote
Old 04-28-2006, 06:55 AM   #12 (permalink)
turbojack's Avatar
Beware, that smell might be tell tale signs of high EGT's and being lean. You might want to look at some type of control that will limit or inhibit a higher boost level under WOT if the WI is not active or functioning correctly.
Old 04-28-2006, 07:49 AM   #13 (permalink)
srt4fun80's Avatar
Member Number: 34189
Trader Rating: (102)
i have thought about this idea, i have engine run up's kit with the pressure sensor switch. i thought about hooking it up to an ebc if there was some way to trigger it so that when the pressure sensor did not detect pressure it would switch the ebc to a low boost mode, hmmmmmm
srt4fun80 is offline   Reply With Quote
Old 04-28-2006, 08:46 AM   #14 (permalink)
I am not sure which ebc you have, but I have a solenoid with a bleed valve hooked up. When driving around normally, the ebc is off, but when I floor it, the injection system triggers, and when the nozzle pressure sensor detects pressure to the injectors, it triggers the ebc, giving me 5 more psi. This way, if for any reason the injection system fails, the ebc never opens, and my boost levels stay stock. Even if the system fails mid run, the boost will go back to stock instantly.
Old 04-28-2006, 12:41 PM   #15 (permalink)
srt4fun80's Avatar
very nice! i do not have an ebc at all. when we put in the gt30r i will get one, and probably set it up exactly like this
