Old 06-06-2008, 03:11 PM   #1 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
Default Meth "Purge" Video
I wanna thank everyone that helped me wire this up in the other thread I started
The reason why I thought of this is because about 2 weeks ago I went to the track. On the way there I had a feeling meth wasnt spraying. So when I parked at the track I powered the Pump from the battery and noticed NOTHING was coming out for 10 seconds. The tank was full cuz I filled it the day before. I think air got into the lines cuz the meth was low.
So after another 5 seconds, meth started to shoot out. I wanted to eliminate the getting out of the car, getting the wire from the power wire of the pump and opening the hood and etc...etc...
All you need is a tiny tap, any more than that and the car will bog with Less than 10.0 A/F.
A tiny tap will show the meth getting injected and drop the A/F some.
If there is anyone that thinks I am going to be doing damage to any part of my car by just tapping, let me know.
ADDED:
The red switch on the left in the video is my "on/Off" switch, which is the toggle switch in the picture above.
With that switch "OFF" the Meth will NEVER Turn on even when it sees the pre-set boost.
Then the momentary switch which I just added today.
FS: HID Fogs Kit - 6000K & 3000K(Yellow) - PM Me
Performance Mods: AGP S3D 48lb - Returnline - Mopar Stage 2 w/o Toys - DW 650cc - TurboXS HPMBC - Maddog STS - MaxxFab 3" DP w/o Cat Magnaflow Muffler - AIS Intercooler - ED LPP - ED UPP w/ HKS BOV - Injen Intake - NGK V-Powers @ .032 - FBM Ported Intake Mani/Spacer - DCR 55mm Throttle Body - DCR Oil Mod - Devils Own MethInjection, M5 - DTEC - AEM UEGO
385HP and 385TQ
Gmanigio is offline   Reply With Quote
Old 06-06-2008, 06:15 PM   #2 (permalink)
caustin8503's Avatar
Member Number: 58347
Trader Rating: (12)
nice setup there. love the indicator light showing when the meth is on.
05 Black SRT-4........stock for now
caustin8503 is offline   Reply With Quote
Old 06-06-2008, 06:31 PM   #3 (permalink)
rolla4now's Avatar
Member Number: 2195
Trader Rating: (15)
nice..
so where's the how-to? what's the wiring looking like?
rolla4now is offline   Reply With Quote
Old 06-06-2008, 06:34 PM   #4 (permalink)
TheFace's Avatar
Member Number: 39238
Trader Rating: (10)
glad to see it worked out for you man. i would suggest having the rpms at maybe around 2000 when you "purge" it to prevent any pooling in the charge pipes or intercooler.
FS- meth kit, 03' s0 injectors, stock springs, stock wastegate, stock cam gears. PM me for info.
evo intercooler on my srt-4
TheFace is offline   Reply With Quote
Old 06-06-2008, 08:40 PM   #5 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
The middle hole with the 2 wires is setup for another light, the one I bought was 120V and would not light up.
I set this up by the info given by other members in the other thread I started.
Basically its from a Devils Own kit that runs a RELAY:
1 - 1 Momentary switch from Radio Shack
2 - Run one end of the switch to #85 of the relay
3 - Run the other end to Ground
And it is basically doing the job of the "boost switch" when you press the button.
Old 06-06-2008, 10:15 PM   #6 (permalink)
Member Number: 26563
Trader Rating: (28)
Just for a second I dont think would hurt anything. Besides....during the burnout it will all get sucked away anyway Just more fuel.........
SRT4V8stomper is offline   Reply With Quote
Old 06-06-2008, 10:23 PM   #7 (permalink)
daniel427ss's Avatar
Member Number: 51325
nice...
daniel427ss is offline   Reply With Quote
Old 06-06-2008, 10:36 PM   #8 (permalink)
where do u have the meth injector placed
Old 06-06-2008, 10:52 PM   #9 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
The injector is about 8 inches from the TB, AFTER the sensor.
Also, it is Literally just a TAP, any more than that and it will bog.
I am thinking about adding another nozzle before the sensor, another M5, wondering if Purging then would be too much meth....
Old 06-06-2008, 10:57 PM   #10 (permalink)
ive turned my pump on when idling and my engine doesnt hesitate like yours n my nozzle is like a m9 or something like that n i am also right before the throttle body-like 5-7inches
Old 06-06-2008, 11:02 PM   #11 (permalink)
then i rev it a little n see that the hks bov spits the meth lol
so what happens is that it doesnt go to the engine while idling is cuz its alot of heavy spray?
Old 06-06-2008, 11:12 PM   #12 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
Ill have to look at my BOV.......
But it is literally just a tap, I cant see there being a puddle....
At idle, how much air is going through that pipe? I think Im gunna rev to 2,000 from now on, like the other guy stated.
Old 06-06-2008, 11:19 PM   #13 (permalink)
if u rev is going to be more dificult to see a diference unles u stay at a steady 2000 rpm n not move anythin more or less. (ive tried it)
n me being so so curious ive also done the tappin n tappin n tapping a couple of times some for like a second to see if my engine does any difference during idle n when i see no difference,
just to be safe,
i do a high rev so anything accumulated goes in for combustion-if not then the bov spits it(of course it wont be all of the meth but whatever left is no deal)
i also wanted to put another injector before the sensor so it can see the meth temperatures
Old 06-06-2008, 11:32 PM   #14 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
I was thinking the same thing about the reving, Although shouldnt the A/F stay at a constant 14.7 no matter the reving??
I will try tomorrow.
I know that if I held it for close to a second, it bogged, just like in the video.
Old 06-06-2008, 11:45 PM   #15 (permalink)
under no load maybe, im waiting for my wideband n i will be checking this too
Page generated in 0.37386 seconds with 11 queries
