Old 11-05-2009, 02:12 PM   #1 (permalink)
mistabones's Avatar
Member Number: 30097
Trader Rating: (18)
Exclamation Meth mix help
I go a coolingmist trunk mount kit 150 pump with dual 5m nozzles. I want to hold HOM in DAB 3. I haven't tryed Anything yet but I wanna run either 60/40 or 70/30, meth/water. I would run full meth but I don't want to at the moment. How should I go about with gettin them mixtures? What do you guys use to mix and how?
Thanks to all in advance!
05 StoneWhite SRT-4
To Many Mods To List...
mistabones is offline   Reply With Quote
Old 11-06-2009, 03:59 PM   #2 (permalink)
Member Number: 75915
The quick, easy and effective way is to mix by volume. So for a 60/40 mix for instance, get a graduated container, fill it 6/10ths of the way with water, then top it off with methanol. Sometimes you will get a reaction that makes the mix milky and produces some heat, and that is normal. It will go away.
You can mix be weight, but frankly going by volume is fine as long as you do it consistently. Plus it is easier.
If you are looking to get your fluid from mixing washer fluid and Heet, a gallon of -20 blue washer fluid mixed with 5 bottles of heat will yield in the range of a 60/40 mix of methanol/water.
Snow Performance Tech
SnowTech.4 is offline   Reply With Quote
Old 11-07-2009, 03:48 AM   #3 (permalink)
Fatal1tyKn1ght's Avatar
Member Number: 63764
Isn't it true that methanol is about 74% the weight of water, so if you thought you were running 50/50 and you measured by volume, you're actually running around 37% methanol to water?
Mopar BOV, Mopar STS, Mopar Stage 1 ECU, BWoody Oil Catch Can, K&N Drop-In Filter, Needswings 3" DP w\Cutout, Maxxfab 3" O2 Housing, SAFCII, FM WGA, AEM Wideband, Aeroforce Scan Gauge, Magnecor Wires, NGK V-Power Plugs, Prothane Motor Mount Inserts, DC Sports Front\Rear Strut Bars, Mopar Stage 2\3 Injectors, Walbro 255 Fuel Pump, Coolingmist Methanol Injection
Fatal1tyKn1ght is offline   Reply With Quote
Old 11-07-2009, 07:43 AM   #4 (permalink)
srt-sparkle's Avatar
Member Number: 8546
Your best bet is to get a uego wideband,scanguage and what mix that you want to use. And try to measure the mix and get the feedback from the car by monitoring the knock retard from the scanguage.
This will help you out to letting you know what the car thinks about the mix. I think anymore than 3 counts of knock and itll kick you out of hom. If you play around with the meth mix and get feedback from the car. Itll let you know where you stand on your mix weather to add more alcohol or more water.
No matter what you do "vengence is mine sayeth the lord" Im still the best,what good is power if your car can barely get traction. Selling mopar toys bezel along with harness PM Me i got pics.
srt-sparkle is offline   Reply With Quote
Old 11-07-2009, 07:56 AM   #5 (permalink)
SRTMIAMI's Avatar
Member Number: 54645
Trader Rating: (12)
google boost juice its good yellow heat is good too
GT3076R-AEM EMS-DP VARI-COOL
WWW.MYFLORIDASRT.COM
SRTMIAMI is offline   Reply With Quote
Old 11-07-2009, 09:04 AM   #6 (permalink)
porksword's Avatar
Member Number: 66925
Trader Rating: (21)
I use two empty washer fluid jugs that I removed the labels from and a EZ pour fuel container. I use jug one for water and one jug for meth. I weighed them out and marked the bottles. This way I can just fill to my line on each bottle and it is measured by weight. Poor both jugs into the fuel container to mix and then into your meth tank in the trunk.
It only requires a little work the first time, but after your jugs are marked its a piece of cake.
porksword is offline   Reply With Quote
Old 11-07-2009, 12:28 PM   #7 (permalink)
mistabones's Avatar
Trader Rating: (18)
Good info thanks guys, I'll try the jug thing. I found a shop that sells VP racing meth, I tested yesterday, and could not hold HOM, but just figured out that my max duty cycle was at 8% and min 3% So dumb..... But I fixed it min 25% max 100%, haven't tested yet but I will soon, *crosses fingers*
Old 11-09-2009, 04:36 PM   #8 (permalink)
Almost. Lets say you have a one gallon jug. We do one gallon of methanol and one gallon of water into a bucket:
Methanol is 6.63 or so LBs/Gallon, water is 8.34 Lbs/Gallon. So you have 2 gallons of mix that weighs 14.97 LBs.
Methanol % = 6.63/14.97 = .44 = 44%
Water % = 8.34/14.97 = .55 = 55%
So by weight, a mix of one gallon of water to one gallon of methanol is a 55/45 instead of a 50/50.
So we typically mix by volume, and then if people want a stronger mix they can do that. As long as you are consistent and tune well you will be fine.
Old 11-12-2009, 01:06 PM   #9 (permalink)
chance@devilsown's Avatar
Member Number: 35658
Trader Rating: (31)
If you mix water and methanol together and it heats up and turns milky the methanol has hydrocarbons and you should return it back to the supplier. People who run meth as a fuel in the cars always test for this.
This is why we don't put dyes in our devilsown brew to hide bad meth. hydrocarbons can decrease the life of the pumps. It gets in the meth usually from tanker trucks carrying oil and then not washing it out properly before caring a load of meth.
Hoesty when mixing meth the most important part is to keep things simple. This way you can always run the same mix and does not throw your tune off.
chance@devilsown is offline   Reply With Quote
Old 11-14-2009, 01:29 PM   #10 (permalink)
Member Number: 52407
Assuming a specific gravity of meth of .7954
Percentage of meth by mass = (quantity meth by volume * 79.54) / [quantity of water by volume + (Quantity of meth by volume * 0.7954)]
7055 is offline   Reply With Quote
Old 11-16-2009, 03:48 PM   #11 (permalink)
You can use 99.9% pure lab grade methanol and get the temporary milky look and and an exothermic (the warming) reaction in the fluid. Adding dye to your mix will certanly not hide that.
Old 11-19-2009, 03:50 PM   #12 (permalink)
TheFace's Avatar
Member Number: 39238
Trader Rating: (15)
mass:
if i were to mix one gallon of -20* washer fluid that is 35% methanol with one gallon of VP M1 pure methanol according to this equation it would yield me approx 62% methanol : 38% water by mass.
volume:
1 gallon = 4 quarts
4 quarts x .35 = 1.4 quarts methanol and 2.6 water
add that to 4 quarts of pure methanol and you will have 5.4 quarts of methanol to 2.6 quarts of water, or 32.5% water by volume and 67.5% methanol by volume.
is this correct?
I'll keep my guns, money, and freedom. You can keep the "change."
"You're a slave to the money then you die"
"It is better to fail at originality, than to succeed at imitation"
evo intercooler on my srt-4
TheFace is offline   Reply With Quote
Old 11-19-2009, 04:25 PM   #13 (permalink)
yea
(5.4 + 79.54) / (2.6 + (5.4 * .7954)) = 62.3%
FYI you didn't have to convert to quarts or even use any unit for that matter. You could just say 1 gal of 35% + 1 gal of 100% =
135 meth
65 water
or because you know you have 67.5% by volume you could just say
67.5 meth
32.5 water
then fill into the formula, they all give the same answer, just easier than doing that extra conversion to quarts, just an extra step you don't need.
All the formula is is: meth/total with the SG of meth thrown in to convert from vol to mass and a 100 thrown in the numerator to make it a percent.
Page generated in 0.18104 seconds with 13 queries
