what are the advantages of meth injection with my set up?
"NOT including the blown transmission!"
and is their a down side to it?
2004 srt-4
i got stock motor
stock turbo
intake
agp waste gate
3" turbo back "catless"
port polished intake mani
walbro fuel pump
stage 1 injectors aka stock
boost sipkes @ 20-21psi and holds @ 17-18psi
Pro's
Youll be able to turn your boost up, Im at 23psi and still rich.
Youll be able to turn up your timing as well
Knock, never happenes
Con's
Youll find new boost leaks from the increased boost
Its addicting
Buying 5 bottles of windshield wiper fluid in preperation for a race weekend, will get you flagged as a suspected meth head
First and Second gear traction
Con's
Its addicting
I agree with all this
I buy 5 gallons like once every 2 months, costs me about $30. Mix that 50/50 so 10 gallons really...lasts me a while.
Looks like you have nothing to control fuel with, SAFC, DSP, etc. So in this situation you'd be working backwards.
Without getting into specifics, yes. I havent tuned mine to the edge of meth injection, but I increased my boost and timing and Im still rich.
Im only using a map clamp right now to pull fuel. I pulled SO much fuel that the pcm freaked out and thought my map sensor was bad. At that point I was still rich.
DSP is the next purchase to get everything running.
are you stock turbo, and if so what psi you at? Also, are you using 100% meth?
Just curious cause im stock turbo, and just got my meth kit...but im probly gonna run a 50/50 mix.
