Old 06-16-2008, 07:50 PM   #1 (permalink)
fr33fir3's Avatar
Member Number: 54378
Default Meth Drip..
Ok so I have an AGP Hard Pipe, With a Devils own kit connected. Its a trunk mount In the left corner of the trunk behind the carpet and the Pump is below it and I used the gromet in the trunk to have a line exit. Then it runs up to a line filter about 2 feet before the M5.. But the problem I got is.. I installed all this on Saturday. And Sat all day sunday.. And I get up for work and its bogging on me today at low speeds.. So bad it was almost stalling..
So I checked the meth tank and lost about 2-5 oz of meth from my tank. So I guessed I had a drip into the IC pipe.. Undid the Clamp and it came dripping out ..Isnt the check valve supposed to stop this from flowing into the Pipe?
I am pretty sure its the Check valve, but any help would be appreciated.. I had to cap the meth line in the trunk, and let the line drip out.
Thanks!
www.Kingclamp.com
For All your map clamp needs.
Major Upgrades:
AGP Motor Mounts, Agp WGA, Agp Hard pipe, Agp Shift Selector, Greddy BOV, LFS 60MM TB, PTP Charge pipe, PTP fuel pump rewire PTP, PTP Wga spring, Walbro 255 lph Fuel Pump. Stage 2 W/toys. Apexi Safc II, Devils Own Progressive W/I, Turbo XS HP MBC, Innovate LC-1 & Gauge,ACT Clutch & Flywheel.
fr33fir3 is offline   Reply With Quote
Old 06-17-2008, 09:37 PM   #2 (permalink)
stl-soldier's Avatar
Member Number: 24780
Trader Rating: (15)
Where is your check valve located? From what I have heard and read, the check valve should be as close to the nozzle as possible since the tank and pump are higher than the nozzle. When the car is shut off, all of the liquid between the nozzle and the valve will drain into the intake piping. Apparently replacing the valve with a solenoid type will get rid of that problem. My kit is still on the way, so I don't know for sure, but that is what I have found the past few weeks of reading.
stl-soldier is offline   Reply With Quote
Old 06-18-2008, 04:42 AM   #3 (permalink)
smokin-ricers's Avatar
Member Number: 10183
Trader Rating: (10)
possibly a bad Check Valve easy fix get a soleniod and your good
contact Chance to see what he will work out with you they have great customer service
I am STOCK
Ya know what I mean
http://www.devilsownonline.com
smokin-ricers is offline   Reply With Quote
Old 06-25-2008, 02:59 PM   #4 (permalink)
scottw03's Avatar
Member Number: 23435
Trader Rating: (33)
I had this same problem with my first CV from Coolingmist. I pulled it off, opened it up and saw that the rubber seal had slid a bit off center so that meth was leaking around it. Reseated it and it was good for awhile and then did it again. I Decided to buy a second CV from coolingmist and now have the old one just after the pump and the new one just before the injector. Since then I have not had a single problem with it leaking into the Coldside pipe.
Hope that helps you fix your issue.
scottw03 is online now   Reply With Quote
Old 06-25-2008, 03:56 PM   #5 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (51)
Our initial checkvalve in 2004-2005 had buna seals. Buna cannot handle as much heat as EPDM. Since we upgraded to EPDM not a single checkvalve failure.
David
Old 06-25-2008, 10:49 PM   #6 (permalink)
scottw03's Avatar
Trader Rating: (33)
David
Yeah, since I have upgraded to the new style one I have not had a problem since.
Old 06-28-2008, 11:34 AM   #7 (permalink)
Member Number: 11814
Trader Rating: (90)
Too hard to resit this because it starts a poop fest but but its good info for those who do not know
Alky kit w/o solenoid valve...not good! - evolutionm.net
Post number 3
Indepth study of WAI injection systems - evolutionm.net
Moral.........dump the check valves people
Page generated in 0.23048 seconds with 11 queries
