Old 08-07-2009, 08:55 PM   #1 (permalink)
AngelSRT's Avatar
Member Number: 53591
Default MAP/TIP Sensor & Meth Injection Issue
I have a sc61 turbo and my motor has just been fully built. im runnin BC stage 3 cams and now this is where im confused. i have direct port meth injection and im running AEM FI/C i still am on the stock stage 0 ecu with the 2 bar and 3 bar map sensor. The meth kit comes with a 2 bar and 3 bar controller. if i use the 2 bar controller will it be ok to have the meth full spray at 15psi. The only reason why i ask this is because i heard about people having issues while running the 3 bar map and tip sensor on a stage 0 ecu. i also have 1000cc injectors that i have calibrated with the AEM.
05 Stone White
???whp ???ftlb on ??psi
AGP 50 Trim
AngelSRT is offline   Reply With Quote
Old 08-08-2009, 10:37 AM   #2 (permalink)
chance@devilsown's Avatar
Member Number: 35658
Trader Rating: (31)
I would recomend running a sepearte 3 bar map sensor to your 3 bar controller. Then just sell the 2 bar controller. Remember you can swith our controllers from 2 to 3 bar mod, for thoughs that go from stage 0-1 to 2-3 and vise versa. or people who are buying new can also go with our dvc-30 controller
chance@devilsown is offline   Reply With Quote
Old 08-11-2009, 12:32 PM   #3 (permalink)
Turbo_SRT_05's Avatar
Member Number: 65676
i would recommend buying a stage 2 ecu and you would be fine.
at least it is scaled for 3.0 bar map already. did you have your stage 0 rescaled or not???? thats prolly why stage 0 and 1 guys have an issue
Turbo_SRT_05 is offline   Reply With Quote
Page generated in 0.11751 seconds with 13 queries
