Old 04-29-2008, 02:19 PM   #1 (permalink)
Member Number: 8193
Default Isopropyl - Anyone use it - try it?
Bottom line is I have 5 vehicals that drink premium fuel. At soon to be $4.35 a gal it's time to do something. Need to run these on cheapo-fuel!
methanol is no longer a cost effective sollution. As prices there are going up as shipping costs rise. Window washer belongs in the washer res and heet belongs in the fuel tank in the winter.
Not looking to get more HP just want to replace premium fuel with cheapo-fuel.
So isopropyl? Affordable and mixes well with H2O.
All comments are as always more than welcome. I know a few of you have tried this. Please share your experiances be they good or bad.
Let leave the delivery system out of the picture for a bit as I will be using components to make up a test system using IDC hopefully and RPM. The Mitsu GSX or my SRT-4 will be the first vehical.
Old 05-02-2008, 09:08 AM   #2 (permalink)
chance@devilsown's Avatar
Member Number: 35658
Trader Rating: (29)
Yea, we did testing with it but i can't seem to find the graphic. Isopropyl is just a tad over water. For what it cost i would just run staight water. Since the gains where so scarce.
chance@devilsown is offline   Reply With Quote
Old 05-02-2008, 09:21 AM   #3 (permalink)
Member Number: 8193
Very good information. Chance, thank you.
I think for this project I may start with water. The Iso maybe just to keep stuff from freezing in early spring or late fall.
Old 05-02-2008, 05:45 PM   #4 (permalink)
Pimpazzberetta's Avatar
Member Number: 29361
Trader Rating: (28)
So what exactly is the chart showing us? Is this a dyno showing gains of each fluid?
Mopar Stage 3R w Toys 388.8 WHP 425.5 WTQ
Mopar CAI,Mopar BOV,S3 C/O's,AGP S3 WGA
SBC 5X,TC BFMIC / t bolt clamps, 55 mm TB, Maxxfab 3" o2,3" catless DP,Injen 3" catback, FBM intake mani
NGK 4306 @ .033, Devils Own W/I w controller
UEGO, Greddy TT, Ultra Lite II 30/30,Scan Gauge
DC Sports STB, MM inserts, Boomba trans mount
LCA, strut tension, Booger bushings,CV,18" Konig's,TCS, D/S Rotors
Pimpazzberetta is offline   Reply With Quote
Old 05-02-2008, 08:55 PM   #5 (permalink)
Member Number: 8193
Chance. your graph show a pretty good gap between Ethyl and baseline in the lower rpm range.
I take it these were consecutive runs. Just pruging lines and swapping tanks. I always wanted to try that.
Cool.
Old 05-03-2008, 12:20 AM   #6 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
that chart doesnt make sense to me. Why do they come back together at 4500rpms?
Last I checked Methanol here was less than $4 a gallon, and isopropyl was ~$10+ a gallon. Methanol has the highest octane also.
Project log pics
Old 05-03-2008, 10:40 AM   #7 (permalink)
Member Number: 8193
Methanol cost me $55 for a 5 gallon pail last year. This year they want $70. I can get it much cheaper from Burke, our shops fuel supplier, but the catch is I need to buy a 55 gallon drum. Just don't have a place to store that much flamable liquid on my property.
The chemical supply stores in my area blame the small quantity cost on shipping. Haz-mat and such. Wish it was only $4 because it works real well.
Old 05-03-2008, 12:24 PM   #8 (permalink)
moparmansrt4's Avatar
Member Number: 50684
Man they are raping you! I buy methanol from a semi-local Napa store for 3.99$ a gallon, but, it is a local supply demand type of thing, not very many Napas sell meth.
Quote: Originally Posted by rollwitstyle View Post
the srt is the worst car to buy it sucks so much balls and tastes like doo doo. buy the t/a they are the fastest cars ever and they taste like steak....... by the way pm me atleast a week in advance if you plan to visit ny
http://www.srtforums.com/forums/f106...ml#post5894846
moparmansrt4 is offline   Reply With Quote
Old 05-03-2008, 05:30 PM   #9 (permalink)
look in the phone book for a propane dealer, they put methanol in the empty tanks to absorb moisture. They should have there own 55gallon drum and should sell you 5gallons worth for a good price.
Old 05-05-2008, 05:08 PM   #10 (permalink)
Member Number: 26091
Trader Rating: (13)
This is a dyno on a 4cly turbo diesel overseas, Totaly different then cars here, no electronics, mechanical diesel pump. It's just to show you the power differences between the mixes. Also these things have tiny and I mean tiny turbos on them that's why the drop off because the diesel is a low reving motor and we took it past it's powerband on the dyno which would have been around 4000rpms.
progressive controlled alcohol methanol injection Kits
BEST PRICE ON PROGRESSIVE KITS PERIOD.
DEPLOYED OVERSEAS- PLEASE NO PM'S
dvldoc is offline   Reply With Quote
Old 05-05-2008, 10:04 PM   #11 (permalink)
Member Number: 8193
Hey dvldoc. Been awhile. I was thinking it kinda looked like a fuso. Anyway I'm going to give it a try. If anything the iso mix will keep the water from freezing here in new england. Remember I'm just trying to stay away from 92+ octaine fuel. Not going to the track to race on 86 pump fuel.
Now the delivery system.
Was thinking of creating a map with injector duty cycle and RPM. Initial onset would be intake pressure triggered.
Question presently is would this be enough info to base a good map/ramp on? And next would come... port injection or a couple smaller nozzles in the up-stream?
Old 05-13-2008, 05:37 PM   #12 (permalink)
srt4fng's Avatar
Member Number: 31722
5 cars all running premium? My heart bleeds for you. Sell one of the cars for gas. Getting tired of people and the price of gas thing. Is it really that bad? Have you had to go without eating? Did you have to sell any body parts? My car to fill up (srt-4) from a year ago is about $7 more. It is something when you add it up at the end of the year but just think about the things you have you don't really need. Sorry had to vent!
srt4fng is offline   Reply With Quote
Page generated in 0.26516 seconds with 11 queries
