Old 10-18-2009, 08:59 PM   #16 (permalink)
SRToad4's Avatar
Member Number: 61889
Quote: Originally Posted by soon2bsrt View Post
I had anywhere from 5-7kr. Installed a basic coolingmist kit running washer fluid and it went to 0kr. something isnt working properly. Whats your setup? what nozzle?
Running the standard 150psi trunkmount kit. I have no idea what nozzle CM gave me, but I told them I'd like for it to support 430hp, so I don't really know which nozzle I received. Threaded it into my upper intercooler pipe, right after the bov but before the throttle body.
Tuned by Tony @ UMS Tuning
390whp/380tq @ 21.5psi / 91 + Meth
SRToad4 is offline   Reply With Quote
Old 10-18-2009, 09:15 PM   #17 (permalink)
SRToad4's Avatar
Yo Cow, what kid did you get? Where did you install it yet? I feel like the car was running better with the original lean tune that realtune gave, instead of my new personal richer tune.
Old 10-18-2009, 10:54 PM   #18 (permalink)
isthatguy's Avatar
Member Number: 49055
Trader Rating: (13)
I have teh coolingmist varicool system with a 250psi pump, m5 nozzle on my interoocler endpipe.
I have a tune for my meth, I just havent hooked it up, it has increased timing, and I need to raise my boost to 25, im running 100% meth.
i have the meth hooked up, but I havnt done the tune yet, because I want to test to make sure its spraying and also am going to order a clog detector from coolingmist. dont want to have any issues
354 whp e3 @ 21psi. 0 knock!
Quote: Originally Posted by KBizzle View Post
your car made me happy in the pants, sorry I didn't track you down to say hey.
-Keegan
isthatguy is offline   Reply With Quote
Old 10-18-2009, 11:27 PM   #19 (permalink)
SRToad4's Avatar
Nice, ya my tune was aleady pretty lean so just hooking up the meth would richen it up and eliminate knock but no cigar...might test later on 2nt
Old 10-19-2009, 01:38 AM   #20 (permalink)
Xx_R/T_xX's Avatar
Member Number: 18749
make sure ur tank is atleast halfway full before actually doin pulls.anything lower might affect the spray and not spray fully to actually notice a diffrence in knock.
BIG TURBO!
Xx_R/T_xX is online now   Reply With Quote
Old 10-19-2009, 02:28 AM   #21 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
Make sure your actual NOZZLE is spraying properly. This involves more than just giving the pump voltage to see it squirt liquid. Remove the coldside pipe and turn on the pump and take a look.
If that doesn't work, play with the boost switch.
The tank does not have to be completely fill to reduce knock, i've ran on half a tank of meth and it's still 0kr. Can you physically eye the level of meth going down? Also check all connections to and from the pump for leaks.
or 16 whatev
WTB: LCA bushings
Old 10-19-2009, 05:09 AM   #22 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
to lower kr you must run 100% meth to see the best results. going to 100% meth you will be using it as a octane booster.
JnR:
blue209 12.23@118 w/1.8 60ft 321hp and 390tq
tkilla 12.28@117.8 w/1.8 60ft new e85#'s coming soon
jrsrt 12.29@116.9 w/1.87 60ft
blackpearl 12.35@114 w/1.960ft 307hp and 363tq
Winecountry 12.32@112 w/1.7 60ft 315hp and 330tq
yellowsrt-4 12.5@112 w/2.0 60ft 307hp,355tq
jlozacr 12.7@110 w/2.0 60ft 301hp and 345tq
bayscksrt 12.9@110 w2.0 60ft 21psi, E85
srt princess 12.9@109 w/1.9 60ft
Kaz109 50 trim 458hp/460tq 11.54@121.78 W/1.79 60ft
reed32 is offline   Reply With Quote
Old 10-19-2009, 05:49 AM   #23 (permalink)
stxsrt's Avatar
Member Number: 37057
Trader Rating: (38)
So I received my meth kit on saturday, and installed it same day. After running all the wires, I went ahead and primed the pump by the instructions. Everything sprayed, and I hooked it back up to the car and went for a drive. Normally, I run around 21-22psi on 91 pump and get around 5-6KR based on temp outside.
3rd gear pulls showed about the same as I've been seing, 3.5kr starting out, rising to 5.5-6kr by redline. Basically no difference in KR as of so far.
Is there any reason that it could not be spraying? I have the boost port running off a tee between my bov/throttle body spacer. Is it not seeing correct boost there?
Any help would be great.
Thanks!
Why is your car having detonation in the first place? You should get your fuel system and tune in check first. Your car has bigger issues than your W/I system.
7.3 @ 101 1/8 mile
http://www.youtube.com/watch?v=RUBJUpApyeE
AEM EMS Tuned by Tampamike
E3 Turbo
Crane 14 cams
M&H Slicks 24s
stxsrt is offline   Reply With Quote
Old 10-19-2009, 10:14 AM   #24 (permalink)
SRToad4's Avatar
Lol, well any car that is tuned via s-afc and running close to 400hp will see a bit of knock. Realtune tuned the car for 93 pump, and I'm running 91 piss gas out here in AZ so the shitty fuel doesn't help.
Anyways, I got around to testing the system by hooking up the line into an empty water bottle, and then doing a few pulls. After the first few pulls, I got out, and the bottle was empty. I found my first problem, which was the 12v wire, not getting power. The connection was bad, so I fixed that and the pump turned on. After 2 more second gear pulls, I did the same thing and now the bottle was about 1/4 full, which shows that it is now spraying. I noticed now that the highest knock I got was about 1.5-2 in 2nd gear, and 3rd gear was giving me about 3-6kr, depending on the rpm of course. I think that my meth content is not great enough. I have 5 bottles of heet, and 3/4 gallon summer blend ww fluid. I think the summer blend doesn't have enough meth in it, so I will be draining the tank and going to get a gallon of the 100% meth pure stuff from a source pretty close.
I will be posting results later on tonight. Let's hope that knock is out of here.
Old 10-23-2009, 12:38 AM   #25 (permalink)
SRToad4's Avatar
I love meth! Finally got everything sprayong correctly and the results are amazimg... 20psi of boost, 0kr thru redline, holding 25degrees of timing, and afr's in the 10.8's! Car pulls SOOOOOO much better and harder!
Old 10-23-2009, 02:06 AM   #26 (permalink)
Member Number: 10107
Meth and dsp are my 2 fav mods so far.
soon2bsrt is offline   Reply With Quote
Old 10-23-2009, 02:19 AM   #27 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (29)
If your car is spraying, your IAT sensor will show a significant drop in temps, if the nozzle is placed before it.
Old 10-23-2009, 09:43 AM   #28 (permalink)
SRToad4's Avatar
My injector is a bit after the iat, just on the other side of the pipe
Old 10-23-2009, 09:52 AM   #29 (permalink)
bribri's Avatar
Member Number: 33121
Trader Rating: (10)
shouldnt it be before the iat? im just curious as i plan on installing my meth kit in teh next few weeks
bribri is offline   Reply With Quote
Old 10-23-2009, 09:56 AM   #30 (permalink)
hercfe's Avatar
Member Number: 19255
Quote: Originally Posted by Kason23 View Post
Run more meth.. Try STRAIGHT HEET. Also be sure to reset your PCM then try a run.
DO NOT RUN STRAIGHT HEET with the standard trunkmount kit and 150psi pump. Only run pure meth with the upgraded pump. The standard pump seals will not hold up to pure meth. Coolingmist even says that on their site and on the box and on the pump.
OP, sounds like you need more fluid in the tank. With the trunk mount kit its hard to run the pump dry, but if you do, your going to need to siphon it a bit to get fluid into the pump again. The key here is to always keep the tank full.
hercfe is online now   Reply With Quote
Page generated in 0.16106 seconds with 13 queries
