Old 06-02-2008, 03:24 PM   #1 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
Default I want to "Purge" my meth kit.
Right now I have a switch wired in that lets me engage my meth kit or turn it off. Its wired in as follows.
This allows me to turn off the kit when I don want to use it, good for tuning and seeing if the meth is working.
But now, I want to power the pump myself w/o getting out of the car and running the power wire to the battery.
How would I wire in another switch to turn the pump on while Im at idle.
The reason for this is because when I went to the track no meth was running because air got into the lines from refilling my tank. So I want to "purge" so I can watch the A/F dip at idle, that way I know its primed and ready to go.
FS: HID Fogs Kit - 6000K & 3000K(Yellow) - PM Me
Performance Mods: AGP S3D 48lb - Returnline - Mopar Stage 2 w/o Toys - DW 650cc - TurboXS HPMBC - Maddog STS - MaxxFab 3" DP w/o Cat Magnaflow Muffler - AIS Intercooler - ED LPP - ED UPP w/ HKS BOV - Injen Intake - NGK V-Powers @ .032 - FBM Ported Intake Mani/Spacer - DCR 55mm Throttle Body - DCR Oil Mod - Devils Own MethInjection, M5 - DTEC - AEM UEGO
385HP and 385TQ
Gmanigio is offline   Reply With Quote
Old 06-02-2008, 03:30 PM   #2 (permalink)
SRToc Member
scotrn's Avatar
Member Number: 12056
Trader Rating: (12)
Easy: Run another wire from the battery to a switch to the pump. Basically taking the pressure switch and relay out of the loop.
scotrn is offline   Reply With Quote
Old 06-02-2008, 03:30 PM   #3 (permalink)
Drachonyx's Avatar
Member Number: 45620
Adding a momentary push button switch that would bypass the boost switch would do the trick, no? This way, the "prime" switch would only work when the system is ON.
I wouldn't wire a switch from the battery since you risk that your system inject all the liquid from the tank in your cold side pipe in case of switch failure. That would be bad.
Drachonyx is offline   Reply With Quote
Old 06-02-2008, 03:31 PM   #4 (permalink)
TheFace's Avatar
Member Number: 39238
Trader Rating: (10)
install a momentary contact switch that will ground terminal 85 of the relay. the toggle would have to be on also for this to work.
TheFace is offline   Reply With Quote
Old 06-02-2008, 03:44 PM   #5 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
Im confuse......
Can someone add a picture from Paint?
LOL
Old 06-02-2008, 03:47 PM   #6 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
This is exactly what I was thinking, a push button when the toggle is "ON".
How do I wire it?
Old 06-02-2008, 03:50 PM   #7 (permalink)
TheFace's Avatar
Trader Rating: (10)
buy this...
Momentary Contact Switch
and connect one terminal of the switch to the terminal labeled 85 on the relay and then connect the other terminal of the switch to ground. essentially you are doing the job of the pressure switch.
Old 06-02-2008, 03:52 PM   #8 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
I think I got it.
Ignition wire.
Ground wire.
Red Power wire from the pump.
Will that work?
Old 06-02-2008, 03:56 PM   #9 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
Quote: Originally Posted by TheFace View Post
buy this...
Im gunna pick that up at radio shack tomorrow and give it a try.
Old 06-02-2008, 03:57 PM   #10 (permalink)
TheFace's Avatar
Trader Rating: (10)
do it how i said above, its safer to just complete a ground
Old 06-02-2008, 03:59 PM   #11 (permalink)
TheFace's Avatar
Trader Rating: (10)
k good luck.
Old 06-02-2008, 04:00 PM   #12 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
Thanks all for the fast responses.
Old 06-02-2008, 06:31 PM   #13 (permalink)
Drachonyx's Avatar
Indeed. The best way to do this would be to add the switch to the ground that activate the relay, like TheFace told you. You're better doing this than connecting a switch on the hot wire of the pump. Anyway, by doing this and using enough wire, you'll be able to put the switch in your console beside your arm/disarm switch.
Old 06-02-2008, 07:17 PM   #14 (permalink)
moparmansrt4's Avatar
Member Number: 50684
If you do this at idle will it cause the engine to bog down or foul plugs? I had my pressure switch set at too low of a psi and when I got a tiny little ptb it bogged down really bad, and ran rough for a minute. Just wondering. I thought about doing this also but I am running two M5 nozzles and thought I would drown my motor.
Quote: Originally Posted by rollwitstyle View Post
the srt is the worst car to buy it sucks so much balls and tastes like doo doo. buy the t/a they are the fastest cars ever and they taste like steak....... by the way pm me atleast a week in advance if you plan to visit ny
http://www.srtforums.com/forums/f106...ml#post5894846
moparmansrt4 is offline   Reply With Quote
Old 06-02-2008, 08:40 PM   #15 (permalink)
fr33fir3's Avatar
Member Number: 54378
Well If you wanted to get really fancy you could run 2 solenoids with a Y in-line which splits to 2 nozzles.. Press the button it will prime the pump and open the dump solenoid but not the main solenoid.. Then your primed all the way to the solenoid. When the pump is triggered normally it opens the primary but not the dump.. This would solve your purge.. Very much like a NOS setup. Cost is a bit but if you want it done right.. Its how I would do it.
www.Kingclamp.com
For All your map clamp needs.
Major Upgrades:
AGP Motor Mounts, Agp WGA, Agp Hard pipe, Agp Shift Selector, Greddy BOV, LFS 60MM TB, PTP Charge pipe, PTP fuel pump rewire PTP, PTP Wga spring, Walbro 255 lph Fuel Pump. Stage 2 W/toys. Apexi Safc II, Devils Own Progressive W/I, Turbo XS HP MBC, Innovate LC-1 & Gauge,ACT Clutch & Flywheel.
fr33fir3 is offline   Reply With Quote
