03-31-2007, 02:04 PM
#1 (permalink )
Member Number: 22973
How to measure meth/water mix?
I'm trying to figure out what the best way to get a 75/25 meth/water mix.
I have VP racing methanol, and i am trying to make a mix tonight,
any advice?
Flame Red SRT-4
Mods:
Magnacore 7.5 MM plug wires - R.I.P.P. Mods Check Valve - AGP Dogbone motor mounts - AGP Transmission Mount - PT Performance wastegate - PTP 3inch Downpipe - Hallman Professional MBC - Exhaust Depot Hot side pipe - JMB UPP with HKS - CoolingMist Methanol/Water kit - SAFC II and tach driver - Hotchkis Springs - NGK AFX Wideband - 274hp/315tq @ 18psi
03-31-2007, 02:14 PM
#2 (permalink )
Member Number: 51090
any advice?
either a measuring cup or a weighing scale
cup is the easier method
http://www.ashland.com/pdfs/technica...sh%20Point.pdf
methanol has real low surface tension/viscosity, it will "pour and splash" everywhere except where you want to get it into
03-31-2007, 02:17 PM
#3 (permalink )
btw use distilled water from the grocery store
03-31-2007, 02:18 PM
#4 (permalink )
yes the distilled water is a must, and i figured a measuring cup would do the trick but i just wanted to be accurate.
Thanks for the help
03-31-2007, 02:20 PM
#5 (permalink )
I'm trying to read the PDF you posted, and i do not quite understand the values. It says meth/water mixture, and % by either, can u explain how its calculated?
03-31-2007, 03:17 PM
#6 (permalink )
methyl alcohol = 0.791g/cc
water = 1.0g/cc
using measuring cup - 1000cc basis:
750ccMeOH + 250ccH2O = 1000cc
750/1000 = 75 v/v% methanol in the methanol/water mix
density = mass/volume
0.791 = mass/750
mass = 593.25gms methanol in the above 75 v/v% methanol/water mix
593.25gms methanol + 250gms water (water = 1.0gm/cc) = 843.25gms
593.25/843.25 = 70 w/w% methanol
therefore, 75 volume percent methanol in water = 70 weight percent methanol in water
03-31-2007, 05:55 PM
#7 (permalink )
ok so if i do 1 cup of water and 3 cups of meth what percent am i looking at
holy shit i wasnt that great in math, but damn dude i dunno wtf is that up there haha. I believe the lower portion of that equation is if i'm measuring the meth out using a scale correct?
03-31-2007, 07:33 PM
#8 (permalink )
3 cups methanol + 1 cup water is what you need to get your 75/25 methanol/water mix
03-31-2007, 08:41 PM
#9 (permalink )
ok thanks man, thats a good bit of info you posted there.
Linear Mode
» Site Navigation
> Other Vehicles
» Network Links
