Old 04-28-2008, 05:55 PM   #1 (permalink)
Member Number: 7855
Default how to lean out with w/I
I'm running stage2, I have the nozzle 2" from the IAT sensor.
I want to know how to lean the car out.
Using meth/water mix adds fuel, so I believe it still is running rich, just not the gas out the tank.
If I run str8 water it cools the IAT, increase timming,; then what uses less fuel, or runs optimal (which is still stage 2 rich).
Please correct me on my ideas, and how do I lean the car out safely with W/I.
Thanks
05 SRT4: PTP Check Valve, 160-tstat, K&N, Alky Injection, and Stage 2
04COMPG is offline   Reply With Quote
Old 04-28-2008, 07:35 PM   #2 (permalink)
Member Number: 63534
Thanks
IMO, meth adds more timing thn water alone.
straight water leans out your afr's. meth richens.
if its too rich:
raise boost
use a fuel controller
or decrease nozzle size.
Drastic_Said is offline   Reply With Quote
Old 04-29-2008, 04:48 AM   #3 (permalink)
Member Number: 57865
Trader Rating: (12)
Default .......
if you want to lean your car out...........buy a safc or dtec..........but yeah^ what he said.
stock
PTP SUCKS!
Their port work cracks(it has on multiple occasions)
fkelchner is offline   Reply With Quote
Old 04-29-2008, 10:18 AM   #4 (permalink)
Member Number: 7855
if its too rich:
raise boost
I'm confused, I'm running rich and want to lean the car out. If I stop using windshield fluid and just use water it should do the job, right. You said water leans out the car.
I don't think I can really raise the boost on the stock turbo with stage 2; I thought the peak eff. of the stock turbo is around 19psi. I am at 17, so that gives me a tiny bit of room.
I dynoed my car with W/I on and off, and it was rich either way. It's like the car made up the diff. with it on or off.
I'm trying to avoid the whole mapclamp thing.
Old 04-30-2008, 04:51 AM   #5 (permalink)
smokin-ricers's Avatar
Member Number: 10183
Trader Rating: (10)
well the only way to lean the car out is to take away fuel by what ever means necessary(and you feel safe doing)
if you are trying to avoid the whole mapclamp thing you might try putting your Stage 1 injectors back in and dyno it to see if your AFR'S are good but that could lean the car out too much
I am STOCK
Ya know what I mean
http://www.devilsownonline.com
smokin-ricers is offline   Reply With Quote
Old 04-30-2008, 05:41 AM   #6 (permalink)
peteblksrt4's Avatar
Member Number: 43767
Trader Rating: (71)
u shouldn't mess with fuel pressure if u dont' have a wideband. i suggest getting a wideband and a fuel controller and tune the car u will love the results. i don't know if straight water leans it out but i do know for a fact that the meth will make the car run richer.
if u have toys run water meth on hom and it will lean out the fuel. if u don't have toys then i highly suggest to get a wideband and a fuel controller. your car will run twice as good when it is tuned.
STARTED SRT CAR CLUB IN AREA PM ME
Best Trap - 1.79 60 FT 12.3090 at 114.53
ported stock turbo
peteblksrt4 is offline   Reply With Quote
Page generated in 0.20555 seconds with 11 queries
