Quote: Originally Posted by
seltech
I did see where he mentioned afrs for max lean power was around 8.5:1 and rich max power was 6.5:1, unfortunatly my AEM uego is older an only reads to 11. I've heard they can be switched to display in lambda which would be what you'd want to look at it in. or i think widebands can be calibrated with the fuels stoich ratio. Not too sure though.
That is based on a stoich of 9-10:1 A/F(it depends who you ask and prob because of the different amount of gasoline in winter and summer mixes), so if you have a gasoline calibrated wideband you just need to convert it . All widebands read Lambda, and Stoich of all fuels is Lambda 1, so the A/F is just a multiplier.
So given your info its hard to tell really what A/F value they use. If you figure 10:1 stoich that some use then it would mean for a gasoline calibrated sensor, using E85 you would tune it to: max lean power(8.5/10=.85x14.7)~12.5A/F and rich max power would be (6.5/10=.65x14.7)~9.5A/F. Hence the reason for E85, you can be much richer than gasoline and still make good power. This is much safer and why I said earlier that figure on 40%more fuel for WOT because you will be much safer then you ever have been on gasoline while still making great power.
